    Standard setting
    5 Posts 2 Posters 455 Views 2 Watching
    • D
      Dopey
      Hi all im new and a little lost, i was mucking around with the camera settings, now it all seems out of adjustment (if you get my drift) panning in and out scrolling around, it seems distorted now, how do i get the original Standard setting back again? thanks
      • GaieusG
        Hi Ton,
        You've probably played too much with the Zoom tool
        http://download.sketchup.com/sketchuphelp/gsu6_win/Content/Z-images/E-Camera_Tools/cam-ToolZoomLarge.png
        Select it from the Camera tools (activate this toolset if it's not active from the View > Tools menu).
        Now when moving the Zoom tool up and down (while holding the left mouse button), you can obviously zoom in and out. Have a look at the Measurement box (VCB for SU 6 users) and notice a "Field Of View" value there. This shows your current camera angle which is easy to (even accidentally) modify with the combination of the Shift modification key and the Zoom tool (used as above).
        So you've probably done this accidentally and you can also fix it using Shift+Zoom.
        • D
          Dopey
          top man i will have a go at putting it right 2morrow again thanks for that
          • GaieusG
            Well, if you haven't been able to confirm that this was/is the problem, don't be happy too early with it! πŸ˜‰
            • D
              Dopey
              seems to have sorted it out now, Thanks
