    Lines Disappear when Vector Rendering
    layout
    6 Posts 3 Posters 2.1k Views 3 Watching
    • SektaS
      Sekta
      Hi All,
      Not sure if this issue has been high lighted here before but have any of you experienced lines and infill colors disappearing when using vector render option in LO. It has happened to me several times to the point where it is getting frustrating 😒 😒
      Stan
      • GaieusG
        I don't know what may cause this but (by any chance) are you not sending a SU model rendered in sketchy styles to LayOut?
        • J
          jhauswirth
          Hi All,
          Stan
          The HLR (hidden line removal) code is buggy. My only suggestion is to try hybrid. It may give you what you need, unless you need only vector output. I have seen the most problems from models that aren't real-life models- i.e. if you couldn't build the model because you can't have 2 boards that occupy the same space.
          • SektaS
            Sekta
            gai,
            Thanks for your response, I never really apply a specific style, I have always assumed the default would apply, I will look in to that and see if it works.
            Stna
            • SektaS
              Sekta
              Gai,
              That did the trick, thanks Mate. πŸ‘ πŸ‘
              Stan
              • GaieusG
                Gai,
                Stan
                Was it not Jeff's suggestion?
