    [Plugin] CPoint at Intersection (1.0.1) — 30 June 2009
    1 Posts 1 Posters 5.3k Views 1 Watching
    • thomthomT
      Deprecated!
      Newer version, compatible with SU8, is available here: http://forums.sketchucation.com/viewtopic.php?f=323&t=30506
      Per request: http://forums.sketchucation.com/viewtopic.php?f=180&t=20258
      Access:
      Plugins -> CPoint at Intersection
      Description:
      It's name isn't that accurate, because it only creates Construction Points where edges cross through faces. Doesn't mark where edges marks edges.
      This doesn't project the edges onto the faces, it only places a CPoint if the edge actually intersects the face. You can select any number of edges and faces.
      Changelog:
      # Changelog
      # 1.0.0 - 30.06.2009
      #       * Initial Release
      # 1.0.1 - 30.06.2009
      #       * Fixed a bug where CPoint where added off the face.
      Deprecated!
      Version 1.0.1
      Deprecated!
