    SketchyPhysics 3x June 27 version.
    95 Posts 12 Posters 28.4k Views 12 Watching
    • P Offline
      Physicsguy1
      Will we be able to embed sound files anytime soon?
      • P Offline
        Physicsguy1
        I tried something similar to javixp's line generator, but the groups I generated are not registered.
        scriptedrandomcube.skp
          CPhillips
          I dont know about the sound. I havent touched that code in a while, but I will see if it still works and let you know.
          • P Offline
            Physicsguy1
            Tracks'n'Treads are much easier. I realy like the new version!
            tank.skp
              CPhillips
              Me too! Self connecting joints are a feature I have been trying to achieve since version 1. I HATE the JCT. Its hard to explain, tedious to use and is the reason you cant copy jointed objects. Its THE major reason I started SPIV. So, I am really glad it turns out to be possible in SP3.
                CPhillips
                Here is an example of a very simple camera system.
                The first example puts the camera eye at the position of the sphere and looking at [0,0,0].
                The second example finds the cone in the scene and looks at that. Note you can drag the cone and the camera will follow.
                The @simulation.camera.set commands parameters are location of the eye, the target and the "up" direction.
                The camera is the same as the camera in the Sketchup API:
                http://code.google.com/apis/sketchup/docs/ourdoc/camera.html
                camerasimple.skp
                cameraFollow.skp
                • P Offline
                  Physicsguy1
                  Now we can create multi-roll games!
                    JaViXP
                    @cphillips said:
                    JaViXP it will work better if you change the onend to this:
                    onend{
                    >    group.erase!
                    Thanks, now it's much better (After a few times playing the animation it becomes kinda slow).
                    PhysicsGuy, well done I like your boxes creator, but there are too much boxes and it'll make the simulation laggy.
                    "Giving up is way harder than trying"
                    JaViXP's Rendering
                    • P Offline
                      phy
                      MAN! That camera is unbelievablly good. ๐Ÿ˜ ๐Ÿ˜
                      Tableau de comparaison de Staxyn s'agit d'un mะ“ยฉdicament uniquement sur ordonnance.
                        JaViXP
                        It does not work for me ๐Ÿ˜ž
                        JaViXP's Rendering
                        • W Offline
                          Wacov
                          It's only half-SP related, but how do you move the ends of a script-created line using script? I've given up trying to replace existing lines on-the-fly, I figure it'd be easier to make them at the beginning of the simulation (or, if possible, before it), then move them every frame. They'd just be there to hold the faces for cloth, and something else I've got planned ๐Ÿ˜„
                          EDIT: Figured it out! Took alot of searching around, the API documentation isn't all that helpful ๐Ÿ˜†
                          I'm SURE this one's overcomplicated, but it's the only way I could find.
                          EDIT: Hopefully, I've fixed the problem ๐Ÿ˜„
                          Should work now
                          • W Offline
                            Wacov
                            That's wierd, but it should be fixed now.
                            • P Offline
                              phy
                              Awesome ๐Ÿ˜
                                JaViXP
                                Thanks it worked now. I have to agree with Phy, AWESOME!!
                                JaViXP's Rendering
                                  CPhillips
                                  Here is a script that makes a simple to use auto connecting joint. In the first frame. The "pin" object automatically connects to any "door"'s it is touching with a hinge and anything else with a fixed joint. What makes it really useful is it copyable. ๐Ÿ˜„
                                  Note I made the "pin" object very dense and no collide. It didn't work very well otherwise.
                                  doorandpin5.skp
                                  • W Offline
                                    Wacov
                                    Thanks for the tips Chris. Here's some movable, breakable objects (Kinda laggy, but fun ๐Ÿ˜„ )
                                    Breakables.skp
                                    Breakable wall.skp
                                      JaViXP
                                      Well done I like it! ๐Ÿ‘
                                      So, Chris, any new features we missed? ๐Ÿ˜„
                                      JaViXP's Rendering
                                      • W Offline
                                        Wacov
                                        Took quite a while to code this right, and I can't get the faces to smooth, but here it is! Seamless cloth!!
                                        (Although it's not copyable)
                                        • P Offline
                                          phy
                                          Um, CPillips how do you use the breakit command or is it a command. I don't mean the split command by the way. Wacov that's fantastic. ๐Ÿ‘
                                          • W Offline
                                            Wacov
                                            I'm on a roll...
                                            Turns out you CAN reset the simulation from within the script. Use this little chunk of code:
                                            @@bPause=true
                                            SketchyPhysicsClient;;physicsReset()
                                            MSketchyPhysics3;;closeControlPanel()
                                            freeDirectInput()
                                            In the scripted field.
                                            I found this near the bottom of SketchyPhysicsTool.rb, it seems to work totally normally for me, but if there's a problem, there's not much I can do about it ๐Ÿ˜„
                                            • 2 / 5
