    SketchyPhysics 3x June 27 version.
    95 Posts 12 Posters 31.3k Views 12 Watching
      JaViXP
      Just a little test. Hit Play and see what happens πŸ˜‰
      Download this file
      "Giving up is way harder than trying"
      JaViXP's Rendering
        Physicsguy1
        YES!! The simulation finally registers in-simulation created objects!
          CPhillips
          @wacov said:
          Thanks guys! One thing I'm finding with the cloth is it tends to collide with itself. That seriously slows stuff down, and it's not really neccessary for a semi-realistic simulation. Can we have object-specific collision detection? So, give the choice to either collide with everything, collide with everything except '...', or collide with nothing but '...'. Keep it pretty intuitive, so using a string finds objects of that name, a var for specific objects, and let us put them into an array if needed.
          So, on the cloth, I'd name all the bars the same, and tell them to collide with everything except each other. You might also be able to make a crude fluid flow effect by creating spheres that only collide with the static mesh.
          In the physics engine you would need materials to do that. So don't expect it until SPIV.
          One thing you could do that might speed things up is to change the connect script to something like this.
          ontouch{|t,s,p|
             connect(t,"ball") if frame==1
              #empty the ontouch event after the first frame.
              #this will ensure that ontouch isnt called again.
             ontouch{} if frame>1
            CPhillips
            @phy said:
            I love the new Script field and script but I was wondering is there any way you can control a scripted joint with a slider or key.
            Not yet. 😞 But I will do that next.
              CPhillips
              JaViXP it will work better if you change the onend to this:
              onend{
                 group.erase!
                Physicsguy1
                Will we be able to embed sound files anytime soon?
                  Physicsguy1
                  I tried something similar to javixp's line generator, but the groups I generated are not registered.
                  scriptedrandomcube.skp
                    CPhillips
                    I dont know about the sound. I havent touched that code in a while, but I will see if it still works and let you know.
                      Physicsguy1
                      Tracks'n'Treads are much easier. I realy like the new version!
                      tank.skp
                        CPhillips
                        Me too! Self connecting joints are a feature I have been trying to achieve since version 1. I HATE the JCT. Its hard to explain, tedious to use and is the reason you cant copy jointed objects. Its THE major reason I started SPIV. So, I am really glad it turns out to be possible in SP3.
                          CPhillips
                          Here is an example of a very simple camera system.
                          The first example puts the camera eye at the position of the sphere and looking at [0,0,0].
                          The second example finds the cone in the scene and looks at that. Note you can drag the cone and the camera will follow.
                          The @simulation.camera.set commands parameters are location of the eye, the target and the "up" direction.
                          The camera is the same as the camera in the Sketchup API:
                          http://code.google.com/apis/sketchup/docs/ourdoc/camera.html
                          camerasimple.skp
                          cameraFollow.skp
                            Physicsguy1
                            Now we can create multi-roll games!
                              JaViXP
                              onend{
                              >    group.erase!
                              Thanks, now it's much better (After a few times playing the animation it becomes kinda slow).
                              PhysicsGuy, well done I like your boxes creator, but there are too much boxes and it'll make the simulation laggy.
                              JaViXP's Rendering
                                phy
                                MAN! That camera is unbelievablly good. 😍 😍
                                Tableau de comparaison de Staxyn s'agit d'un mΠ“Β©dicament uniquement sur ordonnance.
                                  JaViXP
                                  It does not work for me 😞
                                  JaViXP's Rendering
                                  • W Offline
                                    Wacov
                                    It's only half-SP related, but how do you move the ends of a script-created line using script? I've given up trying to replace existing lines on-the-fly, I figure it'd be easier to make them at the beginning of the simulation (or, if possible, before it), then move them every frame. They'd just be there to hold the faces for cloth, and something else I've got planned πŸ˜„
                                    EDIT: Figured it out! Took alot of searching around, the API documentation isn't all that helpful πŸ˜†
                                    I'm SURE this one's overcomplicated, but it's the only way I could find.
                                    EDIT: Hopefully, I've fixed the problem πŸ˜„
                                    Should work now
                                    • W Offline
                                      Wacov
                                      That's wierd, but it should be fixed now.
                                        phy
                                        Awesome 😍
                                          JaViXP
                                          Thanks it worked now. I have to agree with Phy, AWESOME!!
                                          JaViXP's Rendering
                                            CPhillips
                                            Here is a script that makes a simple to use auto connecting joint. In the first frame. The "pin" object automatically connects to any "door"'s it is touching with a hinge and anything else with a fixed joint. What makes it really useful is it copyable. πŸ˜„
                                            Note I made the "pin" object very dense and no collide. It didn't work very well otherwise.
                                            doorandpin5.skp
                                            • 2 / 5
