    ๐Ÿšจ Skimp | 25% Off until March 30 Buy Now
    [REQ] Align Multi (Res) Drop Multi? Undrop Multi?(Res)
    8 Posts 3 Posters 2.6k Views 3 Watching
      Didier Bur has an align tool but it's not a "multiple align" ๐Ÿ˜ฎ
      A sort of drop align wanted!
      Does this yet existing?
      And a drop Multiple?
      Didier Bur has something similar in the "Component spray" but some hard to make in place and randomized ๐Ÿ˜„
      So If you want the complete pyramid, just One Align multiple
      • One Drop Multiple
        ("Drop" and "smart drop" don't make that)
        Of course I can made this with SketchyPhysics in a big box but...๐Ÿ˜„
      Undrop is solved by Me Myself and I and Tig and Thomthom โ˜€
      My first ruby plug ๐Ÿ’š
      • PixeroP Offline
        Pixero
        The first alignment part can be done with my JS Align script.
        http://www.pixero.com
          @Pixero : Many thxs! Tricky plug ๐Ÿ‘
          Works like a charme ๐Ÿ˜Ž
          Except that all volumes go to the origin ๐Ÿ˜„
          Edit : Ok I can make Align X/Max/Max then move result to the wall
          or calculate the actual wall position from origin and use custom... ๐Ÿ˜‰
          PS
          Maybe the new "Undrop" is not to difficult to make? (see first post)
          • PixeroP Offline
            Pixero
            Have you tried using custom value?
              yes see my previous post ๐Ÿ˜‰
              I have just to make a little move after an align MAX or calculate the position wall for a direct custom result ๐Ÿ˜‰
              As Custom is absolute and not a relative one ๐Ÿ˜‰
              • CadFatherC Offline
                CadFather
                Hi Pilou - i posted this just now http://forums.sketchucation.com/viewtopic.php?f=180&t=20233
                though it is not exactly what you are looking for..
                  Yes, I have seen it, very design! โ˜€
                  And there are many combinaisons with the JS Align plug ๐Ÿ˜‰
                    Undrop multiple
                    Funny things ๐Ÿ˜„ (click image)
