Noob with Podium plugin problems
Hi guys,
I dowloaded Podium 1.6 trial version. It downloaded into the correct folder, but when I open up SU there is NO plugin menu. What am I missing.
Please exuse my ignorance, I am just a lowly carpenter trying to use sketchup/podium to work up some plans for an up coming remodeling project for my wife.
Any help you guys can give me would be greatly appreciated.
Thanks -
When you install Podium, by default it creates the plugins in a folder for "SketchUp 6". Either you can go find that "SketchUp 6 Plugins" folder and move the files to your SketchUp 7 Plugins folder, or uninstall Podium and when you reinstall it, watch for the install folder and change it to SketchUp 7.
I've tried uninstalling podium and then reinstall with no luck, I also tried moving podium files from sketchup 6 ( default install) to SketchUp 7, also with no luck.
Any other suggestions? I really want to try out the free eval before buying the software.
Anyone know why I can't get podium to run or why I have NO plugin menu what so ever.
I'm getting desperate guys, help a newbie out, I'm sure I'll have alot more questions once I get started.
Thanks for checking out my question -
Try this - its the help page on the Podium site. http://www.suplugins.com/index.php?p=page&page_id=Help#Install
Oh, and did you restart Sketchup after you installed Podium? That is necessary after installing any plugin.
Register LoginAdvertisement
