    Need help debugging
    3 Posts 2 Posters 287 Views 2 Watching
    • PixeroP
      Pixero
      In my script jsAlign (http://www.pixero.com) odd things happen if you align edges/vertices inside a group.
      The face gets somehow outside the group and at the origo.
      See example file.
      Anyone knows why and how to fix it?
      jsAlign_bug.skp
      • TIGT
        I think that
        Sketchup.active_model.entities.transform_entities(t,v);
        should be
        Sketchup.active_model.active_entities.transform_entities(t,v);
        You might also need to apply a transformation to these any entities equivalent to the original group's transformation...
        Something like...
        ## set their 'point'...
        t1=ORIGIN-group.transformation.origin
        t2=Geom;;Transformation.new(point)
        ## re-set for be new stuff - 'gp' here is a group...
        gp.transform!(t1)
        gp.transform!(t2)
        ... Hope this helps...
        • PixeroP
          Pixero
          Thanks, that seem to work. (I didnt have to use that last part.)
