    Push Pull through multi-layered walls - How Do I Do It?
    4 Posts 2 Posters 627 Views 2 Watching
    • G
      gclyde
      Hi Folks,
      I am very new to SU, and have downloaded a new plug in for creating multi layered external walls. However, I do not seem to be able to push-pull past the first layer.
      How do I do it?
      Ta
      Gra πŸŽ‰
      multi layer wall test.skp
      • GaieusG
        Hi Graham,
        What exactly are you trying to PushPull?
        Can you upload an example file?
        • G
          gclyde
          Added a test multi layer wall as requested.
          Gra
          • GaieusG
            You can. Problem is that one side or that volume you are trying to PP through the wall is somewhere inside the wall. So from the surface, you may be trying to PP it through but then it flips and disappears and appears on the other side.
            Right click the wall > Hide and PP your volume. Then go to Edit > Unhide and unhide your wall. Note that it's grouped (probably multi layered) so if you want your PP'ed volume to interact with it, you'll need to edit it (or all the groups) first (or copy the volume into the groups)
            multi layer wall test1.skp
