    Multiple Face Extrusion in SU
    9 Posts 7 Posters 10.5k Views 7 Watching
    • E
      EDMON242004
      Hello there, I am just wondering if it is possible in SU to choose or select multiple faces and then extruding or offsetting them all at once, I usually do is to pick then extrude/push, select then push,it a hard really when modeling a lot of windows, hope someone of the masters out there can lend me a hand, thanks you 👊
      • mitcorbM
        mitcorb
        Edmon:
        There are several ways to do this.
        If you are interested in doing this with basic Sketchup, you can extrude one face a specific distance, mouse over the next face and double click. The next face will be immediately extruded to that distance, and so on for each subsequent face.
        If you wish to go beyond this, you can try Fredo6's Plugin Joint Push Pull. Further, Didier Bur, I believe, has a tool similar in function. These are freely available. Just do a search in this forum for Joint Push Pull. Monsieur Bur's plugin is available in Ruby Library Depot. You can Google search the Depot. There may be some other plugins, I just can't recall. Hope this helps.
        mitcorb
        • GaieusG
          Push_Pull_Vector by Didier is one of those plugins that Mitcorb mentions and extrude a selection of faces (along a pre defined vector). See similar plugins (and download this one as well) from here.
          • Jean LemireJ
            Jean Lemire
            Hi Edmon242004, hi folks.
            See attached SU file for ideas.
            Pulling multiple shapes.skp
            • E
              EDMON242004
              Hi everybody, I have just downloaded the plugin joint push pull, it's the one that I'm just looking for, thanks for the help,
              • Chris FullmerC
                Also, if you're feeling dventurous, I just finished a tutorial that shows how to write multiple push/pull script in Ruby. Ruby is a great language to program in, and multiple pushpull is an easy script to write. So if you're interested in trying your hand at ruby scrits, check it out here:
                404 Not Found
                (www.sketchucation.com)
                (though its actually the 2nmd part of a series, so you might want to start with the first one).
                Chris
                All my Plugins I've written
                • E
                  EDMON242004
                  Hi Cris, thanks for the link, I always wanted to learn ruby scripts I will give it a try, thanks again. 👍
                    seems a cool thread talks of that yesterday 💚
                    • dukejazzD
                      dukejazz
                      For them that don't like adding plugins
                      and is a little easier then
                      mothod of Jean Lemire » June 19th, 2009, 7:33 am
                      Here is a SU (SU way) 2D Multiple Face Extrusion
                      It can be done
                      Thus
                      By makeing a 3d base volume ancher then use the move tool.
                      Like this
                      Trick or skill:
                      Alot of plug-in can be done in sketchup with some insight.
                      Also you can unlock the axes of the move tool with the arrow keys too.
