Export of animation to png
Help...
I have an issue with SU exporting animation to PNG files that I want to get help on. After I have exported four or five animations from different files, the files that are then exported are blank. I have to close SU and restart it, and then it works for 4-5 more exports before it starts exporting blank files again. Since I'm trying to work on a video that has hundreds of these exports, I really need to get this fixed. Any one seen this? Is it a known bug? I have searched but haven't found anything.
Hi Dik (and glad to see you made it "in"),
By "exporting 4-5 animations" do you mean full animations or 4-5 png images only?
In any case, I could imagine that somehow the computer memory gets full, doesn't clear and therefore it stops exporting. -
I'm glad to be back in...
The scenes range from, 2-200+ frames. I have 3G of RAM so I hope I'm not running out of memory. Nothing else seems to be effected, the frames (files) that are exported are simply empty (32K). This behavior started just recently (the last 2-3 weeks).
Gaieus,
You were right I guess. If I don't open Movie Studio while exporting, I don't have a problem. I guess SU or MS doesn't play well with memory.
Oh, good to hear this. I guess they both hang on the memory too much (but I'm not a very technically educated person to tell it sure).
Register LoginAdvertisement
