    Learning VRay
    11 Posts 6 Posters 2.3k Views 6 Watching
    • R
      rcossoli
      Hello to everyone, and these days when I have some time I'm learning slowly VRay, I always work with kerkythea, but now I'm trying with this software, I see very well and gives excellent results for work I saw here and in other forums.
      what really need is advice for configuration, and gave me some teofas, but if someone has something to comment to do so.
      sorry my inglish
      exterior
      http://img30.imageshack.us/img30/3886/imagen12copia.jpg
      interior: is necessary to work many textures and lighting
      http://img522.imageshack.us/img522/6301/interior6copia.jpg
      THREEDIMENSIONSWEB dot COM
      • M
        moghamdi
        very nice render.
        I like your exterior more, can you please share your exterior scene settings?? πŸ˜„
        • R
          rcossoli
          The outside has a basic configuration, physical room, the sun zise in 3, and then indirect lighting, 1st Irradiance map and 2nd light cache.
          the truth is that just because the other values are not used. πŸ˜•
          • D
            DzineTech
            I'm surprised to find you are using IR+LC as these images are very noisy and look more like DMC images. I suggest you change your DMC sampler settings to either Adaptive Subdivision 0,2 or Adaptive DMC 2,6. This should help smooth out the jaggies and also I suggest you lower the DMC sampler noise threshold to 0.001
            If you are getting blotches on the interior shot once the noise has cleared then increase the Hsph subdiv's on the irradiance map
            HTH
            • R
              rcossoli
              thanks for the advice of confuiguracion.
              the truth is the part that will wear off, because the VRay has many parameters to adjust
              • R
                rcossoli
                another takes the same interior, with some parameters modified
                http://img132.imageshack.us/img132/3390/interior9copia.jpg
                c&C are welcome.
                • S
                  Sir
                  the 2nd interior is better than the first, cleaner and smoother. maybe a bit too light tho?
                  • J
                    JaViXP
                    I like the latest render, I see you have found how to improve the AA feature.
                    "Giving up is way harder than trying"
                    JaViXP's Rendering
                    • C
                      cadmunkey
                      Nice images, are the 2 large trees in the first shot 3d or 2d clipmaps? (not the palm). If so, I'd be interested to know where you got them.
                      • R
                        rcossoli
                        thanks for the comments
                        Trees are download on the 3d warehouse. (the leaves have an alpha map)
                        this is the link
                        http://sketchup.google.com/3dwarehouse/search?q=smart+tree&btnG=Buscar&styp=m
                        • R
                          rcossoli
                          one shot more!!!
                          http://img190.imageshack.us/img190/1286/interior14copia2.jpg
