    Noobie question: How do I copy and flip?
    3 Posts 3 Posters 553 Views 3 Watching
    • T
      TNTRower
      Hi guys!
      Noobie here. This is the firt time using any 3D modeling tool. Loving it so far. I have been using this for a little less than a day and am already hooked.
      My question is how do I Copy this element (Screenshot attached) and flip it around so it is mirrored? This is the footboard section of a loft bed. I don't want to have to redraw each of those stiles again.
      Any help is greatly appreciated!
      • Chris FullmerC
        Welcome aboard!
        In SketchUp, you can select the object, then move a copy (that is to activate the move tool, press ctrl and you get a little plus sign on the cursor which means you will make a copy when you move it). So "move a copy" over to where you want it to go. Then scale it to -1 (make sure you grab the correct scale handle or else you flip it in more directions than you really want).
        Hope that helps.
        Chris
        All my Plugins I've written
        • R
          Rodentpete
          @chris fullmer said:
          Welcome aboard!
          Or while the copy is selected right click and select 'flip along red/green/blue axis'
