    A different use for SketchUp...
    9 Posts 6 Posters 1.9k Views 6 Watching
    • EscapeArtistE
      EscapeArtist
      Okay, we usually have architectural stuff here and the odd car or other item rendered for display. I use SU for something a little different: stained glass windows. Here's the latest one I've made, and the SU images. Panel is 26 3/4" sq.
      • GaieusG
        Hey, those are different colours! πŸ˜‰
        Anyway, cool. You could easily make renders for "more real" pre-viz. of these stained glass panels. Even installed in the (models of the) rooms they are designed for.
        • daleD
          dale
          Yes Gaieus is right, stained glass renders pretty well. Here is one I did fooling around in on of the forum glass challenges a while back. Modeled in SketchUp rendered in Kerkythea
          • soloS
            solo
            That looks cool.
            Hmmm...gives me an idea for the next challenge, how about a stained window challenge where not only the texture of the glass needs to be present but also the filtered light and even colored light/refracted, and even diverted spectrum effects?
            http://www.solos-art.com
            • daleD
              dale
              It's a great idea. There are so many environments that stained glass can be placed in, ( back lit from the light inside a building, in a stained glass lamp, backlit from sunlight outside of a building). Plus the textures would be a challenge.
              • EscapeArtistE
                EscapeArtist
                @solo said:
                That looks cool.
                The intersection of two hobbies, I'd definitely enter that one.
                  That's a very good idea. And if needed, you can print out full size paterns to work from.
                  • Chris FullmerC
                    I'll dig around and see if I can find the pattern I made for the Welsh flag stained glass panel I did (well, did 1/2 of 😳 ). I made the pattern in SU, but never rendered it. (I never actually finished the project because I burned out the motor in my glass grinder and never got around to fixing it....been 3 years now!)
                    Chris
                    All my Plugins I've written
                    • EscapeArtistE
                      EscapeArtist
                      Burned it out? You know you're supposed to cut little pieces to size, not grind the sheet to size right? πŸ’š
                      Lol, a new grinder isn't that much - heck, check Craigslist. Usually once a month someone is selling all their stuff.
