    Face Selecting
    2 Posts 2 Posters 385 Views 2 Watching
    • P Offline
      Palmerj
      I am currently working with sketchup models on a dell optiplex 755 and I am having problems selecting faces. when I try and select a face it will select the face behind it, or to the side of it, ETC. Now I have found were is said you go to the "openGL" under the preferences tab and check the "correct reversed picking driver bug" but that does not seem to work. Any Suggestions?
        You have already asked this here:
        http://forums.sketchucation.com/viewtopic.php?f=11&t=19553&p=161757#p161757
        please, don't double post. If there's a solution, it should go into the same topic.
