    Follow me an keep! Need help
    6 Posts 3 Posters 780 Views 3 Watching
    • charly2008C
      charly2008
      Hi to all,
      Follow me and keep process stops always at the same point. I couldn't find the reason. Thank you in advance.
      Karlheinz
      Untitled.skp
      • B
        Bert
        Hi Charlie2008
        I have used your model and I succeeded the follow-me operation.
        What I have done is that I started the operation and run close to were you had problem,then zoom very close and I was able to continue the operation going one segment at a time. Pay attention because there are some very small line segments
        Salutations (Best regards) Bert
          I have remade something similar after seen your exemple 😉
          I have taken your bottom base line, welded it (I suppose that is here the problem !
          (for any reason your baseline is not well welded! )
          I extrude it with Didier Bur Plug "Projection"
          I draw a diagonal line on surface with Fredo6 Tools "On surface"
          I erase the top facets so I obtain your inclined curvated wall surface
          I draw a rectangle
          And Apply the FAK
          No Problemo 🤓
          PS For the selection I have a very more simple method!
          In your there is another curve ! No need it!
          ligne.skp
            If you must select segment after segment it's very painful! 😮
            Just make a "box selection"(left to right) and no problem if your upper curve is well "connected" or "welded" then add selection of the "rectangle" and make the FAK 😉
            • B
              Bert
              I very well agree with you Pilou, But I have assumed that Charly2008 did not have the "Weld" plugin.
              Also may be I have not made it clear. What I did is
              Activate the follow-me tool then
              clic on the rectangle and
              follow the upper curve with the mouse up to the point where it stops following and
              then zoomed in quite a bit and continue following the curve
              • charly2008C
                charly2008
                Thank you to all who answered,
                today i tried it again with a copy of the line and it worked. this step belongs to a quick tutorial for road design.
                If you are interested have a look here: http://forums.sketchucation.com/viewtopic.php?f=15&t=19578
                Comments are welcome
                Karlheinz
