    Right click > add texture
    10 Posts 4 Posters 958 Views 4 Watching
    • J
      Jorgensen
      Is there a rubyscrip that allow one to rightclick on a group / component and then add current matarial to all faces inside ?
      I have searched but not found one 😞
      Jorgensen
      sketchup pro 2016 16.1.1449 64 bit | windows 10 pro | i7-3770k @3.5 GHz | 16gb ram | gtx 780 ti / gtx 980 ti | nvidia driver 368.39
      • thomthomT
        http://forums.sketchucation.com/viewtopic.php?f=180&t=13711
        • J
          Jorgensen
          I don't see how ? Can Remove_CG_mat.rb affect only one object ?
          • thomthomT
            ah. don't think so.
            But that's rather simple task though. You really need a plugin for that?
            • J
              Jorgensen
              If there where one it would be nice. I could use it - for an example - to change the material on some furniture, that consist of a lot of groups, faces and so...
              πŸ˜„
              • R
                RickW
                I've started one, but it's not ready for release yet. I may have to bump its priority. The challenge is nested G/C's... 😐
                RickW
                www.smustard.com
                • thomthomT
                  ...and what would expected behaviour of the group/component contains a component further down? should it make it unique? Or affect all others?
                  • M
                    mpowell1234567890
                    Triple click on the model, Right click then select reverse face.
                    Then "With the whole model selected" use the same material sample and apply it to the model.
                    • J
                      Jorgensen
                      for me it should affect all faces inside the group / component - and all groups and components inside those.
                      thanks πŸ˜„
                      • J
                        Jorgensen
                        Anyone that has the time to write this script ?
