    How to model a good sofa??
    6 Posts 4 Posters 1.1k Views 4 Watching
    • M
      moghamdi
      where can I find a tutorial for modeling a good sofa like in attached image??
      • EscapeArtistE
        EscapeArtist
        Don't know about a tutorial for a model exactly like that. Whatever was used to model that appears to be quad oriented rather than triangle. The only thing that I could add that might be useful is that maybe the "Soap Skin" and definitely "Subdivide and Smooth" SU plugins would be necessary for the model.
        • soloS
          solo
          Believe it or not, it's not that difficult to do using a few key plugins (thanks again to our code wizards), however!.... this is extremely high poly modeling and due to the subdivisions needed for smooth meshes it will cripple SU pretty fast.
          http://forums.sketchucation.com/viewtopic.php?f=15&t=17097&st=0&sk=t&sd=a
          http://www.solos-art.com
          • M
            moghamdi
            I will try "Subdivide and Smooth" plugin and see if it will help.
            thanks to you all.
            • arail1A
              arail1
              May I ask - what program was the sofa modeled in originally?
              • M
                moghamdi
                I think it was 3d max
