    Projecting a line to a curved surface
    10 Posts 2 Posters 1.2k Views 2 Watching
    • charly2008C
      charly2008
      Hi to all,
      does anybody have an idea how to project the marked line to the curved surface? I couldn't find not yet a solution. Is there a possibility?
      Karlheinz
      Alpen41.skp
      • Jean-FrancoJ
        Jean-Franco
        Hi Karlheinz,
        I've used Shapebender see the picture. But first you've to rotate your form.
        Jean-Franco
        • charly2008C
          charly2008
          Hi Jean-Franco,
          thank you for your fast reply. But i have problem to get it work. I turned the model. Then drew the line along the groups base as shown in your image. Here the first problem appears. The line was divided into two pieces. I tried to weld it, but without success.
          Karlheinz
          Alpen41.skp
          • charly2008C
            charly2008
            Hello Jean-Franco,
            After i drew the line again and again, somehow it has worked anyway. But now shape bender doesn't highlight the line. I will be crazy soon. What i do wrong?
            Karlheinz
            Alpen41.skp
            • charly2008C
              charly2008
              Hi Jean-Franco,
              Problem solved. I forgot make the face to a component. Now it works. You have helped me very much. I will write a Tutorial about the complete Process soon in this topic : http://forums.sketchucation.com/viewtopic.php?f=15&t=19364
              Karlheinz
              • Jean-FrancoJ
                Jean-Franco
                Karlheinz,
                I'm pleased to see that it works for you now.
                Sorry not to have mentionned your face must be a group or a component
                Great. And thanks for your future tutorial I'm interested too.
                Jean-Franco
                • charly2008C
                  charly2008
                  Hi Jean-Franco,
                  the next problem is that the shape bended profile is now mirror inverted!!!!!! I tried also before the shape bending process with a rotated 180 degree rotated face but the result was the same.
                  Karlheinz
                  Alpen41.skp
                  • charly2008C
                    charly2008
                    Problem solved!
                    I had only to flip along component's red axis, then the result is correct.
                    Karlheinz
                    • Jean-FrancoJ
                      Jean-Franco
                      Karlheinz,
                      the reason is the Start and the End of the segment and the curve are not in phase.
                      To change that you have to use the arrow Up/Down of your keyboard just after Shapebender creates the wiring and before you click on Enter.
                      PS: Of course you can also flip along the red axis as you did. But I recommend you to try within Shapebender as suggested.
                      Jean-Franco
                      • charly2008C
                        charly2008
                        Thankyou very much for this advise because i faced a problem with the method i used.
                        But after toggeling start and end point, the result shows some faults. I will correct them manually.
                        Karlheinz
                        There are no problems, only questions.
                        Alpen41.skp
