    City Gen and rounding edges [split "off"-topic]
    16 Posts 5 Posters 1.6k Views 5 Watching
    • R
      rv1974
      Could City Gen also round/fillet edges created?
      Yes "just rounding the edges" )
      • thomthomT
        Isn't there a plugin that does that?
        Can't say I see the purpose of that for a street generator. ❓
        • R
          rv1974
          Yes there's pretty defective one (imho)
          • thomthomT
            Care you explain?
            • R
              rv1974
              Did you ever used fillet.rbs?
              1/ It fillets connected edges only
              2/ no 0 filleting
              3/ it doesn't work with crosses ( "L" only)
              4/ after complaining that something is wrong this tool keep staying.
              5/ it works with preselected lines only
              You know at the end of this reply I come to conclusion that you have write a good acad like fillet tool 😆
              • thomthomT
                Haven't used fillet.rb, no.
                Sounds like this would be a separate new tool. Maybe some of this code can be used for that...
                @rv1974 said:
                2/ no 0 filleting
                Why do you want that? wouldn't that leave everything unchanged?
                How else would it work?
                • R
                  rv1974
                  @rv1974 said:
                  2/ no 0 filleting
                  1/ 0 radius filleting is some kind of trim\extend - very powerfull
                  2/ there should't be nothing wrong to select the tool before geometry
                  • thomthomT
                    So the lines you start out with wouldn't actually touch each other?
                    (Could a moderator split this recent series of post into a new thread? This is describing a different tool; I'd like to keep this thread related to street generating.)
                    • GaieusG
                      done
                      • S
                        sepo
                        Thom could you plese explain how the plugin decides the radius of join between 2 roads. It would be good to have some sort of control over it so it can be used in real situations rather than purely for visual/game stuff. I have not install it yet so I might be shooting blanks here. 😉
                        • thomthomT
                          You mean the Street Generator? http://forums.sketchucation.com/viewtopic.php?f=180&t=19493
                          This topic was split into a new thread as it evolved into a request for a different tool. It'd be nice if the dicussion on the Street Generator was kept there and the discussion of this tool kept here.
                          (Sorry for being a pain, but this is turning out a wee bit confusing fast...)
                          • S
                            sepo
                            lol... I was not sure if to post in the street generator tread ...sort of not to polute...Ok I will repost my comment in the (now I know ) correct tread so mods can remove it from here if they wish.
                            • K
                              kwistenbiebel
                              I am desperately searcing for a good fillet tool for roads.
                              For a Yield Analysis I need to draw lots of roads manually and I am haing a hard time making the fillets....
                              An automated plugin that does this as described here with a radius parameter would be a time saver....
                              • thomthomT
                                @kwistenbiebel said:
                                I am desperately searching for a good fillet tool to join roads.
                                For a Yield Analysis I need to draw lots of roads manually and I am having a hard time making the fillets....
                                An plugin that does the fillets as described above with a radius parameter would be a time saver....
                                Like this: http://forums.sketchucation.com/viewtopic.php?f=314&t=19493 ??
                                • K
                                  kwistenbiebel
                                  A plugin that does the fillets as described above with a radius parameter would be a time saver....
                                  • K
                                    kwistenbiebel
                                    Thank you thomas.
