    Supodium problems
    extensions
    5 Posts 5 Posters 825 Views 5 Watching
    • Z
      zumo
      Hi can anyone help!!
      When I render in podium it goes through the motions and in the preview window nothing appears, I have reinstalled it and I still have the same problem plus when I save it nothing happens, It did work until a few days ago!
      sketch up 7
      latest version
      vista
      • R
        remus
        are you in perspective mode? i think some of the other camera types can cause strange things to happen...
        • troyhomeT
          troyhome
          Do you have shadows on and is your time set to a daylight hour?
          IOviz.com
          SU Pro 2024 PC
          • A
            alpro
            You'd probably do better asking this at the Podium forum, but there are several things you can do. 1) Try a different preset, if that doesn't work 2)You could have a problem with a texture, try doing a clay render, if it works then its a bad texture, if it doesn't work 3)You could have a problem with a component, paste your model in a new file and start deleting one component at a time till you get a render. This seems to solve most problems with a blank render.
            Mike
            • S
              sepo
              Is this happening to all of your models or is it only to a specific one?
