    Make all selected unique script?
    7 Posts 4 Posters 622 Views 4 Watching
    • P Offline
      Pongo1471
      hi, iv been looking for a script to make all selected unique instead of making them all just #1 ,for sketchup to number them all. Dose anyone know of a script that can do that?
      Im a content creator on IMVU and looking to make life easyer when making scenes, it requires placing an array of nodes across the scene so that you can place things on those spots, but it needs a certain naming veriation for every node (for example furniture.Floor01 furniture.Floor02 furniture.Floor.278). iv been looking for a way to just mass make uniqu and then in notepad after exporting from sketchup i could just use the find replace tool to remove the # and then presto, correctly named nodes ^_^ as without paying someone i doubt im gonna find a script that also names them right
      Any help at all pointed in the right direction would be a BIG help to me and many others!! πŸ˜„
      i looked into dynamic content but after getting it to creat the nodes correctly i found that theres an issue with the 2 different naming veriations, one seems numberd perfectly where as the exporter only reads the other box (whole load of excitment while that lasted lol)
        remus
        Do you need the names to be in any specific order, or does each component just need to have a name in that format?
        If the former, could get tricky, if the latter, it should be fairly easy.
        • P Offline
          Pongo1471
          well the naming of them just goes
          furniture.Floor01
          furniture.Floor02
          furniture.Floor03
          furniture.Floor12006
          etc
          but as for the order of which they are numberd it dont matter, only as long as they are all uniquly numberd ^^, even if the # is still there between the Floor and the number, we could just open notepad and your find replace to mass remove the # , it would be a grate help ^^
          i also run a help site for people using sketchup for IMVU which has helped many people start off and this would help me and many others πŸ˜„
          for what ever reason if people are intrested my site is http://www.neo1471.c-o.in
            ### Makes all selected instances unique and edits names...
            ### Copy all of this text into a text-file called something like
            ### makeallselectedunique.rb - in the Plugins folder...
            ### type 'makeallselectedunique' in the Ruby console
            ### it works on current selection
            def makeallselectedunique()
              ints=[];Sketchup.active_model.selection.each{|e|
                if e.typename=="ComponentInstance"
                  e.make_unique ### make instance unique
                  ints.push(e) ### keep list of these instances
                end#if
              }#end each
              ints.each{|e|name=e.definition.name
                ### name with '#nn' on end, e.g. ABC#2
                prefix=(name.split("#")-[name.split("#").last]).to_s
                prefix=name if prefix==""
                ### e.g. ABC
                suffix=name.split("#").last.to_i ### e.g. 2 as integer
                suffix=1 if suffix<1
                ### check all extg defs for possible new name
                Sketchup.active_model.definitions.each{|d|
                  suffix=suffix+1 if d.name==prefix+suffix.to_s
                  ### e.g. ABC2 exists so try to make it ABC3 etc
                newname=prefix+suffix.to_s
                e.definition.name=newname ### renames definition
                puts name+" >>> "+newname ### put a # in front of this line to stop console printout
              }#end each
              return nil
            end#def
            • P Offline
              Pongo1471
              Thank you its a God send!! ill have a toy about with it before putting it on my site (if thats ok)
              would you like me to link your name to any site or profile page? its just so people know who made there lives easyer! πŸ˜„
                OK. Just mention TIG from here...
                • ApofisyA Offline
                  Apofisy
                  >     end#if
                  >   }#end each
                  >     ### e.g. ABC
                  >   }#end each
                  >   return nil
                  > end#def
                  Hello,
                  i need a similar script but i don't know ruby πŸ˜„
                  i need to edit all names but not all definitions and just add a counter after the name like this:
                  furniture.Floor.01,furniture.Floor.02,furniture.Floor.03,...,furniture.Floor.10,furniture.Floor.11,furniture.Floor.12,....
                  where name is the name of the object.
                  Also if there are some object like furniture.Floor.01 and furniture.Floor.02 for example the script can start to add counter from 03.
                  Can you edit your script with my requests please? πŸ’š
                  I'm waiting for your reply, thank's. πŸ˜„
