    Working on new scripting system.
    68 Posts 14 Posters 11.9k Views 14 Watching
      CPhillips
      I havent changed anything to make joints stronger. In fact I have been spending a bunch of time trying to figure out how to make a weaker kind of joint. 😄
      • W Offline
        Wacov
        Any news on release yet... nothing specific, but a couple of weeks? More that a month? Throw me a bone here 😄
          CPhillips
          I am sorry, I really dont know at this point. I am making good progress but so much of it is unfinished and during the summer the amount of time I can spend on it is limited. I might setup a closed beta so that you guys can start testing some of the new scripting features.
          Lately I am working on doing the scripting interface in wxSU instead of webdialogs. That should make it a lot simpler to add new features. Also I am going to add some settings to fixed joints to allow them to be "springy". Its hard to explain but kinda fun.
            BTM
            That's almost possible now; just move the joint fairly far away from the object that's attached to it.
            • W Offline
              Wacov
              A closed beta would be great! I appreciate it's just you, working on this huge plugin... if it's done when it's done, that's fine by me 😄
              • P Offline
                Physicsguy1
                Chris, can you tell us the new features that will be in the next release?
                  CPhillips
                  Almost all of the new stuff is outlined in this thread. Mostly it is the new scripting system which should make a lot of new stuff possible.
                  Beyond that there is the ability to set object density and maybe adjustments to how stiff some joints are.
                    darkPhysics
                    Can we get SP3 X April 6 even if it's not done? I'm pretty sure many of us here would like to see new features. Please, CPhillips.
                    • P Offline
                      Physicsguy1
                      We can't pressure him too much. This is a big project. Besides, we won't be getting it soon, because he is probably still debugging and working out all the little errors. We would probably just have what we have now,and a few of the new features, but with a whole lot of problems.
                        CPhillips
                        Sigh, I guess a little pressure is warranted. Its been a while since a release. Ill work on an interim release but no promises.
                        • P Offline
                          Physicsguy1
                          Thank you! I'm guessing most of the features outlined in this topic will be in it.
                          • P Offline
                            Physicsguy1
                            I have a script problem.
                            results=UI.inputbox ["Drive Options"], [""], ["Motor|Thruster"], "Drive Options"
                            if results=["Motor"] then @@motor=1
                            . I can't figure it out. It might be related to Sketchyphysics. The motor that retrieves @@ motor will spin regardless of input. I can't control it!
                              BTM
                              > end
                              You put 'if results=["motor"]. it should be ==, not =. When you put =, it sets @@motor to 1. if you change it to ==, it will work properly.
                              • P Offline
                                Physicsguy1
                                if results=="Motor" then @@motor=1;end
                                if results=="Thruster" then @@thruster=1;end
                                Still won't work.
                                  BTM
                                  Still won't work.
                                  then do this:
                                  if results[0]=="Motor" then @@motor=1;end
                                  if results[0]=="Thruster" then @@thruster=1;end
                                  • P Offline
                                    phy
                                    Shoot! It's not working after all. It had worked(I thought anyway).
                                    Tableau de comparaison de Staxyn s'agit d'un mГ©dicament uniquement sur ordonnance.
                                    • P Offline
                                      phy
                                      if results=="Motor" then @@motor=1;else;@@motor=0;end
                                      if results=="Thruster" then @@thruster=1;else;@@thruster=0;end
                                      This worked fine for me.
                                      • P Offline
                                        Physicsguy1
                                        Thank you, •BTM. Now I have another question for Chris Phillips. How can I stop the sim using script? I have an idea for a safety script for very laggy model sims that would make good use of it. I can set a timer to stop the sim automatically after 5 or 10 seconds if things get out of hand, or if I made a bad mistake.(like forgetting to set a message box to appear only once, not every frame.)Would be pretty useful. I might try to form it into a plugin, if I can.
                                          CPhillips
                                          Not yet. But I could probably add that without too much trouble.
                                          • G Offline
                                            GoldenFrog
                                            Do you use python or ruby?
                                            Remember, great minds think alike, and fools never differ.
                                            • 3 / 4
