    Working on new scripting system.
    68 Posts 14 Posters 14.5k Views 14 Watching
      CPhillips
      Sigh, I guess a little pressure is warranted. Its been a while since a release. Ill work on an interim release but no promises.
        Physicsguy1
        Thank you! I'm guessing most of the features outlined in this topic will be in it.
          Physicsguy1
          I have a script problem.
          results=UI.inputbox ["Drive Options"], [""], ["Motor|Thruster"], "Drive Options"
          if results=["Motor"] then @@motor=1
          . I can't figure it out. It might be related to Sketchyphysics. The motor that retrieves @@ motor will spin regardless of input. I can't control it!
            BTM
            > end
            You put 'if results=["motor"]. it should be ==, not =. When you put =, it sets @@motor to 1. if you change it to ==, it will work properly.
              Physicsguy1
              if results=="Motor" then @@motor=1;end
              if results=="Thruster" then @@thruster=1;end
              Still won't work.
                BTM
                Still won't work.
                then do this:
                if results[0]=="Motor" then @@motor=1;end
                if results[0]=="Thruster" then @@thruster=1;end
                  phy
                  Shoot! It's not working after all. It had worked(I thought anyway).
                  Tableau de comparaison de Staxyn s'agit d'un mГ©dicament uniquement sur ordonnance.
                    phy
                    if results=="Motor" then @@motor=1;else;@@motor=0;end
                    if results=="Thruster" then @@thruster=1;else;@@thruster=0;end
                    This worked fine for me.
                      Physicsguy1
                      Thank you, •BTM. Now I have another question for Chris Phillips. How can I stop the sim using script? I have an idea for a safety script for very laggy model sims that would make good use of it. I can set a timer to stop the sim automatically after 5 or 10 seconds if things get out of hand, or if I made a bad mistake.(like forgetting to set a message box to appear only once, not every frame.)Would be pretty useful. I might try to form it into a plugin, if I can.
                        CPhillips
                        Not yet. But I could probably add that without too much trouble.
                          GoldenFrog
                          Do you use python or ruby?
                          Remember, great minds think alike, and fools never differ.
                          • W Offline
                            Wacov
                            Ruby, it works through the SketchUp API 😄
                              Dakta
                              Shit guys we need documentation.
                              Like, mega documentation.
                              I'd be happy to contribute once I've gotten back up to date with everything here, there's just been a lot of change since I was last active.
                                GoldenFrog
                                Oh, Yeah, I forgot. I dont know whether this has been asked before, but when will SPIV be released? 😄 Could you (CPhillips) post a sample part of the script?
                                Thx
                                • soloS Offline
                                  I so badly want to use SP properly, anyone know of tutorials that start from stupid and go all the way to genius?
                                  Easy to follow stuff, like video would be an advantage.
                                    drfabinex
                                    I'm with you Solo. I'd say right now I'm a Sketchyphysics dunce. Not completely illiterate, but definitely spending more time staring at the corner with a cone hat than keeping up with the class. I've gone through the Wiki and if anyone has any great tutorials to share that would certainly rock.
                                      GoldenFrog
                                      Chris, is there any deadline for the release date of SPIV? You once said that connecting joints was going to be a snap. How are you going to do that?
                                        Davidfi1
                                        Any news?
                                        How long had passed?
                                        • W Offline
                                          Wacov
                                          It's been a very long time since any news 😢
                                          • 3 / 4
