    Looking for a way to remeber aspects
    2 Posts 2 Posters 316 Views 2 Watching
    • X Offline
      xymox
      Hi around!
      i got some models, which have to get rendert in a "studio environment"
      i need different aspects from every model. but from all the same....
      so, is there a way, or a plugin .. which could handle this(stores aspects)?
      hope you got what i mean.. my english got a little rusty...
      respect and thanks!
        remus
        If the aspects you need are the same for every model, id do it by first rotating copies of the component to the desired by angles then moving each copy to its own layer.
        Then by turning all the layers bar one off and making a new scene you can control the visibility of each angle using scenes.
        When you then go to change the subject, you only need to edit the component and your aspects are left unchanged.
