    πŸ«› Lightbeans Update | Metallic and Roughness auto-applied in SketchUp 2025+ Download
    Some new Renders..
    73 Posts 46 Posters 15.1k Views 46 Watching
    • cucsat2003C Offline
      cucsat2003
      thanks you for quick tut,it's very helpful for me
      • majidM Offline
        majid
        all rendder are verry nice, also trees are excelent silver!!!! from where did you got 3d ones ( not 2d palms...)
        • F Offline
          fymoro
          I have no words to tell you, incredible, very nice job... πŸ‘
          http://www.thearender.com/cms/index.php/news/featured-artists/137-frederic-yves-moro.html
          • broomstickB Offline
            broomstick
            I think I already said it, but the way you blend people in the renders is absolutely in-cre-di-ble. Wish I had the time to do the research for the perfect image each time!!!
              darcemac
              Amazing and inspiring renders!!!
              Yourself and Freeagent are setting the benchmark higher every time!
              I always use yours and freeagent's images as a reference when tying
              to do my exterior shots
              Silly question but how does sketchup handle such a large model with textures?
                silver_shadow
                Hi there, thanx, not too many textures were used creating these renders. To be honest sketchup can take a nice punch on poly, but do suffer on the texture side and makes it really slow as your model gets bigger. The first model, with the weird columns were giving problems on the rendering side so i got more ram for my 32 bit machine, and it held up ok for the renderings. I do not have that powerful machine at the office neither at home, (office = quad core with 4 gig ram 32 bit windows. Home 3.4 core due pro with 2 gig ram) But there is always a fear...is this model too big, will it render, what if it does not render, what do i change. I usually go back to my textures and export them to a file, and then check for abnormal size and dimension, and change that first and try again till it do render.
                  darcemac
                  Hi Silvershadow,
                  Thanks for the quick reply, one more silly question;
                  what would you consider too large for a texture or
                  what is your average size?
                  also did you happen to do the rendering for a winery project
                  in Sommerset West called False Bay Vineyards?
                    silver_shadow
                    No sorry didn't do that project
                    I usually use 1250x1250 as a max size texture, if my textures give problems to render
                    Vray can manage bigger textures...but sometimes do run into trouble when the model gets bigger. So id say 1250x1250 is probably quite safe
                      trillium
                      hi silver shadow, thank you so so much for all your great inspiring works! i just stumbled upon your eye candy posts(WOW!!!!) and then this one!! not sure if you are still check this post but i have a question for you- how did you do the cascade water feature in the first project? thank you so much again for all your previous tutorials. i just started SU and i'm already so inspired by people like you!!!!!!!! β˜€
                        bahri
                        wow very good job
                        its pleasure to ur work...
                        should i call U Mr.Perfecto
                          remon_v
                          I'm trying to get a nice reed texture like yours in the model, so I downloaded it from cgtextures. here's a quick try
                          http://i22.photobucket.com/albums/b336/remon_v/1-1.jpg
                            trillium
                            hi silvershadow, thank you sooo much for all your amazing works and great tutorials on so many of your threads!!! i wonder if you could share with us some tips on how you did the forground sandy beach and background images in photoshop. they look so seamless!!! i felt the same when i saw freeagent's bush lodge with the dry grassland foreground. you guys inspire me to learn more about post processing! thanks again! β˜€
                              silver_shadow
                              thanx, sorry for the missing images. (Stupid photo bucket errors)
                              The thing i sometimes do and usually work well is say for the sand or grass, render your model with a flat color, like sandish for sand or greenish for grass. Then in photoshop drop a image over that grass or sand, and say it should be overlay or any of those that suit your needs. and use an eraser to control areas.
                                trillium
                                thank u !! β˜€
                                  chango70
                                  The original images have been deleted by photobucket.
                                  • P Offline
                                    pibuz
                                    that's true.... 😞 😞 😞 😞
                                    I WANNA SEE THEM!!!!!
                                    WEB (ita) - https://filipposcarso.wixsite.com/ordinentropico
                                    • EscapeArtistE Offline
                                      EscapeArtist
                                      Bandwidth Exceeded.
                                        silver_shadow
                                        fixed πŸ˜„
                                          chocolate_fou
                                          these are really cool renders.great work silver shadow..by the way, i'm new here.just admiring your works.i hope someday i could also do stuffs the way you do. keep it up!!!
                                            silver_shadow
                                            sorry for the issues on photobucket
                                            • 3 / 4
