    Tileable Textures
    11 Posts 8 Posters 5.2k Views 8 Watching
    • Al HartA
      Al Hart
      GIMP and PhotoShop have routines to make patterns tileable, but I wanted something we could run directly from SketchUp.
      This new feature of NprTools uses an algorithm described by Paul Bourke
      Here is an example of taking a non-repeatable swirl pattern, making it tileable and placing it in SketchUp.
      Original Pattern
      http://wiki.renderplus.com/images/3/3b/Original1.PNG
      Tileable Pattern from NprTools
      http://wiki.renderplus.com/images/7/70/Original1_r.PNG
      Repeating Texture used in SketchUp
      http://wiki.renderplus.com/images/thumb/3/38/Radial-swirls.jpg/400px-Radial-swirls.jpg
      This example was not very tileable in the first place, but makes it easier to see how this works. It works well with patterns, like grass or carpets, which are almost tileable. But it will make any pattern tileable.
      See: Tileable Patterns
      Al Hart
      http://wiki.renderplus.com/images/e/ef/Render_plus_colored30x30).PNG
      IRender nXt from Render Plus
      • S
        ScottPara
        Al,
        Are we talking "tiled" textures or making a texture seamless? For myself, I would want grass seamless so that the repeat is not to obvious. Just trying to make sure I understand what you are trying to do before commenting more on some alternatives to look at that I use regularly.
        Scott
        Love the fact that some HATE my avatar.....
        • Al HartA
          Al Hart
          Al,
          Scott
          I put together a sample for you.
          This is a grass image grabbed from the internet. For real grass you would probably use an image looking down on the grass. But the imperfections in this image will make it easier to see how this works.
          http://wiki.renderplus.com/images/c/ca/Grass1.jpg
          Grass after processing in Tileable Textures. There are some lines in it. I think when I work on the algorithm more thay will go away.
          http://wiki.renderplus.com/images/b/ba/Grass1_r.jpg
          New grass texture tiled in SketchUp.
          http://wiki.renderplus.com/images/2/21/Grass2.jpg
          Al Hart
          • S
            ScottPara
            OK that is what I thought you meant. I gave the grass image a shot (maybe 1 minute) in one of the 2 programs I use to make images seamless. If this is an idea for you I would suggest you look at Luxology's Imagesynth and the way that works. It is fairly stable and does a great job for the money.
            Scott
            • jujuJ
              juju
              Scott, you do know that ImageSynth2 has been available for a while. Available as standalone or Photoshop plugin.
              • S
                ScottPara
                Yes, I have used it for a while. It is not always the most correct solution but it has more options than some of the others. Version 2 is faster but not anymore stable on textures above 2k....even on a beast of a machine.
                Scott
                • soloS
                  solo
                  I recently got a new texture making toy that has taken the number one spot from my previous texture making app Imagesynth2.
                  Check it out: http://www.pixplant.com/
                  http://www.solos-art.com
                  • daleD
                    dale
                    Looks like a nice tool but ...alas not for Mac
                    • S
                      ScottPara
                      Pete it is FAR better than Imagesynth in my opinion but does not have the control that Imagesynth has.
                      Scott
                      • ashscottA
                        ashscott
                        I'm creating repeating tiles of bricks but the bricks vary in color and size/shape throughout one texture - my understanding is that automatic systems such as pixplant can't help in this instance?
                        Just some stuff I do with Sketchup.
                        • GaieusG
                          Well, pixplant has a feature to incorporate repeating patterns (if there are any of course). Also you can add as many "seeds" (i.e. colour variations) as you wish.
                          (Which brings into my mind that I should go out and take a bunch of photos for my pixplant...)
