    SketchUp7 updated install looking for .msi file
    10 Posts 5 Posters 4.0k Views 5 Watching
    • F Offline
      Fletch
      So I'm having an interesting prob w/ SU7 free,
      I'm using Vista 64bit home premium.
      downloaded SU7's update on May 1st.
      I tried installing it tonight (did not un-install SU7 first...
      now the intsallation sequence is asking me:
      "The feaure you are trying to use is on a network resource that is unavailable." "Click OK to try again, or enter an alternate path to a folder containing the installation package 'GoogleSketchUp7.msi'
      I'm not at work on a network, and my download came in .exe format.
      so I hit Cancel, and it says it's aborting the install because SU7 can not be removed.
      So I went to remove it manually, and it says "The installation source for this product is not available.verify that the source exists and that you can access."
      help?
      Fletch
      Twilight Render Cross-platform Plugin for SketchUp on PC or Mac
        remus
        Hmmm, i think msi is the installer SU uses, so something has obviously gone awry with it.
        Any more details about the original install? I dont suppose you installed to a weird location that might have tricked SU in to thinking it was a network license?
        • F Offline
          Fletch
          hmmm... well, I don't think so.
          I'm the admin on my home machine. the installer I downloaded was 11/18/2008 GoogleSketchUpWEN.exe.
          I installed it fine, used it for a few months just fine. But then it started giving me errors about a missing .dll.
          now when I try to un-install or install the SU7 update I downloaded from May1, it gives me this window
          I see the file it's looking for here is called 7zS59B0.tmp - so it gives me a clue that it must have happened around the time I installed 7zip 4.65 (x64 edition) ?!
          Interestingly - another oddity - SketchUp 7, after I installed it, did not have the SketchUp program icon. Also 7Zip does not have it's program icon. I didn't connect the 2 events before, but now I see SU7 and 7zip must share something in regards to naming a file they are installing?!
          I'll try un-install for 7zip I guess...
          It won't let me uninstall SU7.
          Fletch
            remus
            My current best guess (emphasis on guess) is that the missing .dll tells SU it isnt a network license.
            I dont suppose you know which .dll is missing? i could PM it to you and see if putting it back makes any difference.
            • AndrewSA Offline
              AndrewS
              We're looking into this problem. In the meantime, I've sent Fletch a PM with some additional things to try. We'll update you if we figure out the cause of the problem, but this is the first I've heard of it, so I don't think it's a common issue.
              Andrew S.
              SketchUp Release Engineer
                Mark Carrabbio
                Andrew, I'm having the same problem.
                I have Vista (32 bit)
                I updated the Nvidia Graphics card and the Dell Bios
                I have SketchUp Pro 7 (student license)
                I installed and uninstalled at least 7 times already. Attached are some of the errors.
                And I get the "Search for A solution online" box which I always try but it never fixes it. I even downloaded a RegCure program to fix registry errors. I've spent too much time already trying to fix this. I have to get working on my model for class which is due in a few weeks. I even hired a cmoputer expert guy to try through a remote desktop connection to fix it. Another $65 down the drain.
                Any help you could provide would be helpful
                • AndrewSA Offline
                  AndrewS
                  All,
                  I suspect the problem in Mark's case is due to a quirk in the way Microsoft Windows Installer technology is processing the SketchUp installer package. I don't think it has anything to do with our installer, but rather, with something going wrong with the internal components in Windows that are used to install our package.
                  I've sent Mark a PM with something to try. If that yields any results, I'll share some of the findings in this thread.
                  Andrew S.
                  • E Offline
                    edarchitect
                    I have a similar problem. SketchUp 7 has been crashing on the first load of the day. It seems to work fine on the second and subsequent loads. It also occasionally crashes with the Ctrl key down. So I went to "Add and Remove Programs" to do a repair. The repair process stopped when it couldn't find googlesketchup7.msi. I searched my computer and couldn't find that file anywhere. Can you tell me where to find it?
                    David E.
                    • AndrewSA Offline
                      AndrewS
                      I didn't want this topic to die forever without any workable solutions, so here's an update. I'm writing it specifically to address the quoted issue, but the general logic probably applies in a wide variety of situations.
                      On Windows, the installer for Google SketchUp uses the Windows Installer technology. That's the case any time you see an MSI file. Ours is wrapped by a self-extracting EXE to make it smaller, but it's an MSI under the hood. An MSI is simply a specially created database file that is processed by Windows Installer in order to perform orderly software installations.
                      Any time Windows Installer performs an installation, it saves an incredible amount of information in the registry and its internal database, possibly up to and including the entire original MSI file. It does this in order to provide a mechanism for performing reliable uninstallations, repair installations, or upgrade installations. That data is put into a special repository that is referenced later when those operations are selected. This is normally totally hidden from the end user.
                      In fact, the way our installer is structured, if you're performing an upgrade, it actually upgrades all of the files and then uses the MSI database to uninstall all files that were put down by the previous installation but are no longer needed for the upgrade version. In this way, it actually performs an uninstall operation during an upgrade, without you even noticing. It's pretty slick when it works.
                      Here's the problem. If the Windows Installer database becomes corrupted, it is possible for the critical data to get lost, causing all sorts of problems down the road when repair, uninstall, or upgrade is attempted. Registry cleaners are also frequently culprits for messing up the Windows Installer information for programs. In some cases, the original MSI data that was saved during installation is deleted, or the registry keys that hold links to that data are deleted, so Windows Installer doesn't have access to it anymore. Then, when you try one of the operations I mentioned before, Windows Installer gets confused. Although it wants to continue, it can't until it's given access to the original MSI that contains all of the critical installer information. Windows Installer assumes the MSI may just be on a network drive that's no longer accessible, so it displays the dialog as mentioned. Although you may be able to work yourself out of the problem by actually finding the original MSI and providing Windows Installer with the path, that's a difficult and error-prone process.
                      Instead, in such a situation, it is probably best to perform an uninstallation of the broken product.
                      The first way to do this is from the Add/Remove Programs menu. If you can uninstall from there, great! Just do an uninstallation and then install the new product.
                      As mentioned in the quoted issue, sometimes that option is unavailable (which again, is caused by Windows Installer database corruption or missing registry keys). In that case, it may be possible to use the original installer for the broken product to perform the uninstallation. You would literally re-run the installer for the original program you installed and choose "uninstall" instead of "modify" or "repair". For instance, if SU 7.0 M1 is broken and you're trying to upgrade to 7.1 when you discover it, then you would want to try re-running the installer for 7.0 M1, at which point you may be prompted to uninstall or repair the installation. Since you're running from the original installer, the Windows Installer database should have access to everything it needs and be able to uninstall or repair cleanly. After that, you could then run the SU 7.1 installer without any problems.
                      If the previous suggestions don't work or are not workable solutions for you, there's another choice. I have never used this program, but Microsoft recommends it in many situations and I found that companies such as HP and Adobe also recommend this for repairs.
                      Microsoft has created a Windows Installer cleanup utility:
                      http://support.microsoft.com/kb/290301
                      Clearly, we can't take responsibility for anything you try to do with this. However, in situations where the SketchUp installation is broken (or any other MSI-based installation, for that matter), you may be able to use this utility to uninstall all previous records for SketchUp, after which you should be able to run the SketchUp installer again and see that everything installs as expected. Although it should leave your preferences in place, there's a chance that those could get messed up. You'd also be subject to losing plugin installations, etc., requiring some work to re-install those items. But, if you're in a bind and there are no other options, this might be a life-saver to get you working again.
                      It is important to stress that errors like this are not due to a deficiency in the SketchUp installer, but are caused by corruption in the Windows Installer database or in the registry, sometimes due to other programs' installers, registry cleaners, or other out-of-the-ordinary circumstances.
                      This won't be of any help to those who have reported the problem before, but I hope it will be of use in the future.
                      Andrew S.
                      • AndrewSA Offline
                        AndrewS
                        With regard to the problem of the Windows Installer being unable to write to C:\Config.msi... I know this issue has been quiet for a while, but I was searching about this earlier today and found a hint that may be helpful, so I wanted to share it.
                        There are some forums where people have suggested that this error is a result of the MSI service not being registered properly. To see if that's the case, you could try the following procedure and then retry the operation that was failing.
                        1. On the “Start” menu, choose “Run”.
                        2. In the “Open” box, type “msiexec /unreg”, and hit ENTER.
                        3. On the “Start” menu, hit “Run”.
                        4. In the “Open” box, type “msiexec /regserver”, and hit ENTER.
                        That will re-register the MSI server, possibly repairing the error.
                        Andrew S.
