    Material Library Creation Question
    6 Posts 3 Posters 1.1k Views 3 Watching
      I'm just wondering if there is a quick and easy way to read a list of color names and their RGB values and create a library. There's at least 120 colors I'd like to have in a library and I'd rather not have to enter each one by hand.
        Jim
        It's fairly easy, can you send the file?
          Hi Jim,
          File has been sent.
          Thank you.
            Jim
            Here's a quick run-down of how. I'm sure there are better ways, this is the first way that worked. And since it worked, I don't have a need to make it better...
            The text file, in this case looks like this (altough Dave's actually was slightly simpler.)
            1  Almond  #EFDECD  (239, 222, 205)  1998
            2  Antique Brass  #CD9575  (205, 149, 117)  1998
            3  Apricot  #FDD9B5  (253, 217, 181)  1949
            4  Aquamarine  #78DBE2  (120, 219, 226)  1958
            And here's the Ruby code to read and parse the color file (which I called c.txt so that I would never remember what it was for.)
            # I'm working in the tmp folder under the Plugins folder
            pf = Sketchup.find_support_file "Plugins"
            tf = pf + "/tmp" # a tmp folder
            # Open and read the file into an Array, using a newline as element separator.
            # Then, iterate over each element in the array, passing each array element in turn to the variable 'line'
            # All code between the do..end loop is executed for each line.
            IO.readlines(tf+"/c.txt").each do |line|
              # Here I use a regular expression to find text between the first space (\s) and the # symbol.
              # Then, chop off the # and strip any whitespace before and after the string.
              name = line[ /\s+(.*?)#/ ].chop.strip
              # Another regex
              # Find the text between ( and ), and store it in the 'color' variable.
              color = line[ /\(.*\)/ ]
              # substitute the ( ) and with nothing (remove them from string.)
              # This should really be done with a more correct regex in the previous step.
              color.gsub!(/[)(]/, '')
              # split the sdtring on the ',' and store the split values in r, g, and b variables.
              # split returns an array. Ruby allows multiple assignment for arrays; a, b, c = [1, 2, 3]
              r, g, b = color.split(',')
              # Add the material to SketchUp
              m = Sketchup.active_model.materials.add(name)
              # Set the materials color. to_i converts the string to an integer.
              m.color = [r.to_i, g.to_i, b.to_i]
            • 2 Offline
              21D
              Hi dave, do you mind sharing that library of named colors?? 😄
              "I prefer drawing to talking. Drawing is faster, and leaves less room for lies."
              Le Corbusier
                I wouldn't mind at all but it turned out I didn't need to make it because Jim already did. You can find it at the link to his blog. I was interested in the Crayola crayon colors which he did a few weeks ago.
                It just goes to show there's nothing new under the sun. 😄
