    Problems with selecting faces
    6 Posts 2 Posters 760 Views 2 Watching
    • A
      akibobot
      **I have problem selecting faces in my desktop pc. I can't normally push/pull faces nor apply materials directly, instead of sketchup selecting the faces I am suppose to select, it is selecting the other faces, which ruins my sketchup model. hope you could help me out.
      Here is the specs of my desktop pc.**
      **%(#0000FF)[----------------
      System Information
      Operating System: Windows XP Professional (5.1, Build 2600) Service Pack 3 (2600.xpsp_sp3_gdr.090206-1234)
      Language: English (Regional Setting: English)
      System Manufacturer: ECS
      System Model: 945GCT-M2
      BIOS: Default System BIOS
      Processor: Intel(R) Pentium(R) D CPU 2.66GHz (2 CPUs)
      Memory: 1024MB RAM
      Page File: 416MB used, 2047MB available
      Windows Dir: C:\WINDOWS
      DirectX Version: DirectX 9.0c (4.09.0000.0904)
      DX Setup Parameters: Not found
      DxDiag Version: 5.03.2600.5512 32bit Unicode
      DxDiag Notes
      DirectX Files Tab: No problems found.
      Display Tab 1: No problems found.
      Sound Tab 1: No problems found.
      Music Tab: No problems found.
      Input Tab: No problems found.
      Network Tab: No problems found.
      DirectX Debug Levels
      Direct3D: 0/4 (n/a)
      DirectDraw: 0/4 (retail)
      DirectInput: 0/5 (n/a)
      DirectMusic: 0/5 (n/a)
      DirectPlay: 0/9 (retail)
      DirectSound: 0/5 (retail)
      DirectShow: 0/6 (retail)
      Display Devices
          Card name: ATI Radeon X1300/X1550 Series
       Manufacturer: ATI Technologies Inc.
          Chip type: ATI Radeon Graphics Processor (0x7143)
           DAC type: Internal DAC(400MHz)
         Device Key: Enum\PCI\VEN_1002&DEV_7143&SUBSYS_30001787&REV_00
      Display Memory: 1024.0 MB
      Current Mode: 1024 x 768 (32 bit) (75Hz)
      Monitor: Plug and Play Monitor
      Monitor Max Res: 1600,1200
      Driver Name: ati2dvag.dll
      Driver Version: 6.14.0010.6925 (English)
      DDI Version: 9 (or higher)
      Driver Attributes: Final Retail
      Driver Date/Size: 2/26/2009 05:41:10, 325120 bytes
      WHQL Logo'd: Yes
      WHQL Date Stamp: n/a
      VDD: n/a
      Mini VDD: ati2mtag.sys
      Mini VDD Date: 2/26/2009 06:58:57, 3565568 bytes
      Device Identifier: {D7B71EE2-3203-11CF-3A6F-0A10A1C2CB35}
      Vendor ID: 0x1002
      Device ID: 0x7143
      SubSys ID: 0x30001787
      Revision ID: 0x0000
      Revision ID: 0x0000
      Video Accel: ModeMPEG2_C ModeMPEG2_D ModeWMV8_B ModeWMV8_A ModeWMV9_B ModeWMV9_A
      Deinterlace Caps: {6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
      {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
      {3C5323C1-6FB7-44F5-9081-056BF2EE449D}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
      {552C0DAD-CCBC-420B-83C8-74943CF9F1A6}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
      {6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
      {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
      Registry: OK
      DDraw Status: Enabled
      D3D Status: Enabled
      AGP Status: Enabled
      DDraw Test Result: Not run
      D3D7 Test Result: Not run
      D3D8 Test Result: Not run
      D3D9 Test Result: Not run]**
      • Chris FullmerC
        In SketchUp, go to Windows > Prefernces > OpneGL and check the boc Correct reversed picking driver bug. That should fix it.
        You mgiht also want to update your video card drivers. They might be outdated?
        Chris
        All my Plugins I've written
        • A
          akibobot
          Chris
          I believe I've done those stuffs too..
          • Chris FullmerC
            You said "you believe" you've done...please double check to make sure that you've done them. If you have reverse picker checked, then uncheck it. If its not checked, then check it. But please try it again, just to be sure πŸ˜„
            Chris
            • A
              akibobot
              Chris
              sir, I've uninstalled and removed sketchup and its folders in my pc. then I reinstalled it, and viola, it's working correctly.
              tnx
              • Chris FullmerC
                Hey, glad you got it working. Too bad it took so much work!
                Chris
