    Import su file to layout for 2d elevatons
    3 Posts 2 Posters 354 Views 2 Watching
      cjay
      I imported a dwg file to SU and made it 3D but how do i import to layout?
      when i open it from layout i only see a small piece of the drawing.
      i wanted to use layout to make elevation views of the project.
      Any help is greatly appreciated.
        Hi cjay,
        Normally when you send your SU model to LO,it will import the same viewport as you are in SU. Make sure however to save your model prior to import.
        Also, in LO, if you double click on a SU model window, you can "navigate" in there just like in SU (pan, orbit, zoom etc.) so you can adjust and fine tune the vie there, too.
          cjay
          ok thanks
