    Get instance parent of selected entity
    5 Posts 3 Posters 507 Views 3 Watching
    • B
      BillW
      If a user has entered a group and selected say an edge - I want to get the parent of the selected edge ie the group
      Typing in the ruby console
      Sketchup.active_model.selection[0].parent
      responds with #Sketchup::ComponentDefinition:0xd3390f0 which is not the instance of the group
      What I need to get is the transformation of the containing group.
      Is there a way to get a handle to the group instance from the selection?
      BillW
      • TIGT
        groupsdefinition.instances[0]
        should return the instance of the group. Note: to avoid a glitch that's not yet fixed with copied-but-unedited groups sharing the same definition, I suggest you use group.make_unique to help too - in some circumstances - might be irrelevant if you are editing that group as that will automatically make it unique ? ...
        • Chris FullmerC
          Check out this method. It sounds like it might work, though I've never used it:
          http://code.google.com/apis/sketchup/docs/ourdoc/model.html#edit_transform
          Returns the transformation of the current component edit session. If a user has double-clicked to edit a component's geometry, this will return the transformation of that component, relative to its parent's origin. This allows one to correctly calculate "local" transformations of a given entity regardless of whether the user is in edit mode.
          but its only available in SU 7.0 (and up). So it might mot help if you know your developing a script that will be run in SU version 6.
          All my Plugins I've written
          • TIGT
            Assuming you want at least v6 AND 7 compatibility then this should return the transformation of the instance of the group containing the selected edge.
            edge.parent.instances[0].transformation
            • B
              BillW
              Thanks both again
              I tried a different tack originally with an add_group/explode combo but TIG the instances option worked perfectly.
              Chris as I am disallowing component edit sessions for the time being and I am coding for SU 6 upwards, I will bear in mind Model.edit_transform for the future.
              BillW
