    Rolling cylinder problem
    15 Posts 4 Posters 1.6k Views 4 Watching
      Thrundar
      I'm trying to get the cylinder (physics set to sphere) to roll down the slope while inside the elements pictured. All the cylinder does is drop straight down through the square frame when I play. When I set the cylinder on top instead of inside, it rolls down the incline. I really need this to work with the cylinder caged or trapped inside the frame.
      Not sure how to put an image in here, but I have a picture of this on my site here:
      http://www.hobbiesaboutus.com/animation-3d.html
      Help?
      • P Offline
        phy
        well explode the boxes totally. then gruop them again and set it to staticmesh
        Tableau de comparaison de Staxyn s'agit d'un mГ©dicament uniquement sur ordonnance.
          Thrundar
          Phy
          Thank's a million! It worked!!
          • P Offline
            Physicsguy1
            If you want the box to be movable, then you can just create four boxes that outline the shape. Then make those boxes a group.
            • P Offline
              phy
              @thrundar said:
              Phy
              your welcome 😛
                Thrundar
                Actually figured out that using the slider hinge worked somewhat for what I needed. However what Physicsguy said. I'm not sure how to make the boxes moveable (I'd like to put an axle in the middle and have all the box frames rotate, with the spheres still being trapped inside, yet able to roll. (I'm experimenting with perpetual motion idea's I've had for nearly 20 years.)
                • P Offline
                  Physicsguy1
                  If you noticed, the frame looks like it is made of four boxes. just turn those boxes you see into components.
                    Thrundar
                    by =Physicsguy= on Wed Apr 29, 2009 6:21 pm
                    Changing them into components did not do anything different. Attached hinge, nothing, attached motor, nothing. (Yes I linked them up right to the appropriate parts) However, having those set as static mesh. unset static mesh and the cylinders fall straight through the box frames.
                    • P Offline
                      phy
                      Could you post the model. You can try scaling everything up.
                        Thrundar
                        by phy on Wed Apr 29, 2009 10:37 pm
                        This is going sound weird, but How do I post a model. Post it here? On google 3d warehouse?
                        • P Offline
                          phy
                          Just post it here.
                          • W Offline
                            Wacov
                            You can post it on the forums using the attach function. Scroll down when writing a reply, and you will see it.
                              Thrundar
                              Ok, trying to upload attachment.
                              Post by Wacov on Thu Apr 30, 2009 7:57 am
                              Thanks Wacov
                              PPM-2.skp
                              • P Offline
                                phy
                                All the boxes have to be a separate group.
                                PPM-2 (2).skp
                                  Thrundar
                                  Aha! When the physics are edited, the 4 parts are changed to BOX physics, Then grouped. I was making them static mesh, which was wrong for what I needed them to do.
                                  Thanks for trying to help here phy!
