    Rolling cylinder problem
    15 Posts 4 Posters 1.5k Views 4 Watching
      Thrundar
      Actually figured out that using the slider hinge worked somewhat for what I needed. However what Physicsguy said. I'm not sure how to make the boxes moveable (I'd like to put an axle in the middle and have all the box frames rotate, with the spheres still being trapped inside, yet able to roll. (I'm experimenting with perpetual motion idea's I've had for nearly 20 years.)
        Physicsguy1
        If you noticed, the frame looks like it is made of four boxes. just turn those boxes you see into components.
          Thrundar
          by =Physicsguy= on Wed Apr 29, 2009 6:21 pm
          Changing them into components did not do anything different. Attached hinge, nothing, attached motor, nothing. (Yes I linked them up right to the appropriate parts) However, having those set as static mesh. unset static mesh and the cylinders fall straight through the box frames.
            phy
            Could you post the model. You can try scaling everything up.
            Tableau de comparaison de Staxyn s'agit d'un mГ©dicament uniquement sur ordonnance.
              Thrundar
              by phy on Wed Apr 29, 2009 10:37 pm
              This is going sound weird, but How do I post a model. Post it here? On google 3d warehouse?
                phy
                Just post it here.
                • W Offline
                  Wacov
                  You can post it on the forums using the attach function. Scroll down when writing a reply, and you will see it.
                    Thrundar
                    Ok, trying to upload attachment.
                    Post by Wacov on Thu Apr 30, 2009 7:57 am
                    Thanks Wacov
                    PPM-2.skp
                      phy
                      All the boxes have to be a separate group.
                      PPM-2 (2).skp
                        Thrundar
                        Aha! When the physics are edited, the 4 parts are changed to BOX physics, Then grouped. I was making them static mesh, which was wrong for what I needed them to do.
                        Thanks for trying to help here phy!
