    Rolling cylinder problem
    15 Posts 4 Posters 1.5k Views 4 Watching
      phy
      well explode the boxes totally. then gruop them again and set it to staticmesh
      Tableau de comparaison de Staxyn s'agit d'un mГ©dicament uniquement sur ordonnance.
        Thrundar
        Phy
        Thank's a million! It worked!!
          Physicsguy1
          If you want the box to be movable, then you can just create four boxes that outline the shape. Then make those boxes a group.
            phy
            @thrundar said:
            Phy
            your welcome 😛
              Thrundar
              Actually figured out that using the slider hinge worked somewhat for what I needed. However what Physicsguy said. I'm not sure how to make the boxes moveable (I'd like to put an axle in the middle and have all the box frames rotate, with the spheres still being trapped inside, yet able to roll. (I'm experimenting with perpetual motion idea's I've had for nearly 20 years.)
                Physicsguy1
                If you noticed, the frame looks like it is made of four boxes. just turn those boxes you see into components.
                  Thrundar
                  by =Physicsguy= on Wed Apr 29, 2009 6:21 pm
                  Changing them into components did not do anything different. Attached hinge, nothing, attached motor, nothing. (Yes I linked them up right to the appropriate parts) However, having those set as static mesh. unset static mesh and the cylinders fall straight through the box frames.
                    phy
                    Could you post the model. You can try scaling everything up.
                      Thrundar
                      by phy on Wed Apr 29, 2009 10:37 pm
                      This is going sound weird, but How do I post a model. Post it here? On google 3d warehouse?
                        phy
                        Just post it here.
                        • W Offline
                          Wacov
                          You can post it on the forums using the attach function. Scroll down when writing a reply, and you will see it.
                            Thrundar
                            Ok, trying to upload attachment.
                            Post by Wacov on Thu Apr 30, 2009 7:57 am
                            Thanks Wacov
                            PPM-2.skp
                              phy
                              All the boxes have to be a separate group.
                              PPM-2 (2).skp
                                Thrundar
                                Aha! When the physics are edited, the 4 parts are changed to BOX physics, Then grouped. I was making them static mesh, which was wrong for what I needed them to do.
                                Thanks for trying to help here phy!
