Translucent jpg image?
Hello,
I am new to this forum.
Can anyone advise as to if there is a way to convert a jpg imported image to translucent?
I am designing a tradeshow display in which the graphic is printed on translucent fabric and need to show that.
Thank you
George -
Sure, apply the image to the desired face in the model. Then open the Material Browser and click on the In Home button (looks like a little house). Then find your .jpg material and select it. Then click on the "Edit" button. At the bottom of the edit window is a transparency slider that you can use to control the overall transparency of the image in the model. hope that helps,
Chris
Chris,
Thank you very much. Works!!
George Braeunig
Register LoginAdvertisement
