    Problem with variables assignement
    10 Posts 2 Posters 814 Views 2 Watching
      davidsuke
      Hi, I'm new in Sketchup and ruby. I'm from Spain, sorry for my english.
      I have the next problem. I want to save in a variable a face and I do it like this
      vec= [] //It is a list of points
      faceIwant = model.active_entities.add_face vec
      //faceIwant is the face i want to save
      f[0] = faceIwant
      But later I use anotther method which do this:
      vec1= [] //It is a list of points
      face = model.active_entities.add_face vec1
      Then, if I watch the variable f[0] i have the "face", not "haveIwant". I don't know why f[0] changes. Someone can help me??
      Thanks!
        f[0] = faceIwant
        But later I use another method which do this:
        You haven't given all of your coding steps...
        I'd use names that reflect the variable 'vec' suggests 'vectors'... I'd use 'points'...
        Also it's not clear where your 'f' comes from - is it an array (list) of faces if so f[0] is the first one ? Setting f[0]=face overwrites the value of the first item in the list: you must use something like 'push' to add it onto the end of the list as shown below...
        model=Sketchup.active_model; entities=model.active_entities
        points=[] ### empty array (list) for points
        ## add some points to this array (list)
        ## let's assume we now have a list of good coplanar points called 'points'
        faces=[] ### empty array (list) for all of your faces
        ## let's add some faces to this array (list)
        face=entities.add_face(points)
        faces.push(face)
        ## empty the points array (points=[]) and add some new points - as before
        ## make another face and add it onto list of faces (using push)
        face1=entities.add_face(points)
        faces.push(face1)
        ## etc etc
        ## face[0] is face
        ## face[1] is face1
        ## face[2] is face2
        ## etc
        Hope this helps...
          davidsuke
          Sorry for my strange constrcution of code. Yes, here isn't it all of my code, the next time I'll put all. Otherwise, thanks fo reply!!
          I'll try and I tell you if it's work, because I think this is that I need.
            davidsuke
            I'l try it and isn't work.
            Look, I have the next code
            require 'sketchup'
            Sketchup.send_action "showRubyPanel;"
            def main1()
            model = Sketchup.active_model
            $entities = model.active_entities
            $selection = model.selection
            floor = []
            pts = []
            pts[0] = [0, 0, 0]
            pts[1] = [100, 0, 0]
            pts[2] = [100, 100, 0]
            pts[3] = [0, 100, 0]
            face = $entities.add_face pts
            floor.push(face)
            pts1 = []
            pts1[0] = [25, 25, 0]
            pts1[1] = [75, 25, 0]
            pts1[2] = [75, 75, 0]
            pts1[3] = [25, 75, 0]
            face1 = $entities.add_face pts1
            edgesFloor = floor[0].edges
            status = $selection.add edgesFloor
            UI.menu("PlugIns").add_item("Make house Copy") {main1}
            I want to view in blue(selected) the edges of the firt square ONLY. But the two squares are selected and i don't know the reason because I only do faces.push() on the first square.
            Any solution??
            Thanks,
              By the way - you don't normally need to make global variables like $selection, doing this can clash with other scripts using the same global-variable ($xxx) - use a class or module and @xxx variables common within that - if you feel you must use $xxx ones give them very unique names unlikely to clash with other's...
              I can now see what's up. When you set faceEdges to be face's edges it quite rightly highlights all of them because the inner loop of edges forming face1 also bound 'face'. You can remove the inner ones by using
              selection.add{face.edges)
              selection.remove(face1.edges)
              Note that you don't actually need to make the arrays of faces unless you need them later as 'face' and 'face1' are directly accessible...
              The .edges methods returns all of a face's edges - if you want to to select only the outer edges of a face use
              selection.add(face.outer_loop.edges)
                davidsuke
                Thanks! but i don't understan't why when I do
                why I have all edges of my project inside edgesFloor, because I only put "face" in faces[0], not "face1".
                It's not possible to have the face "face" alone doing faces[0] = face???
                  If you had found the edges to 'face' and put them into an array BEFORE you made 'face1' then that would work OK. However, you don't try to find 'face's' edges until after you have added 'face1'. At that point 'face' and 'face1' are coincident/coplanar in the Z-plane so 'face1' is effectively inserted into the middle of 'face'. 'Face' then has four extra edges - i.e. the internal loop that it shares with face1 ! So you must either find the edges to 'face' before making any other coplanar faces or later on remove the edges for 'face1' from any selection.
                  Try making this manually - you'll see that if you make 'face1' on top of 'face', then 'face' will become a doughnut when selected, double-click on it and its face and edges are highlighted - including the inner-loop !
                    davidsuke
                    ok! I understand now!! You're a master!!!
                    But i hsve the last question for you, sorry lol
                    Well, can you tell me how can I have the edges of my "face"after add "face1"???
                    I know the second method, remove the lines of the "face1" from selection, but it's possible take only the edges of "face" directly??
                      will add the outer edges of face and ignore the inner ones at any point in the code after face is made... even after face1 is added...
                        davidsuke
                        Thanks!!! Now I can continue with my project!!
