    HELP WITH THIS CODE, please?
    5 Posts 3 Posters 518 Views 3 Watching
    • D
      DIEGO-RODRIGUEZ
      can someone tell me how to correct this code?
      Gracias.
      elcorto Argentina
      model = Sketchup.active_model
      entities = model.active_entities
      pz=[]
      pz[0]=[0,-100.mm,0]
      pz[1]=[100.mm,-100.mm,0]
      pz[2]=[100.mm,-81.mm,0]
      pz[3]=[0,-81.mm,0]
      edges = entities.add_edges([0, 560.mm, 0],[600.mm,560.mm,0],[600.mm,560.mm,720.mm],[0, 560.mm, 720.mm],[0, 560.mm, 0])
      facez = entities.add_face pz
      facez.followme(edges)
      http://img5.imageshack.us/img5/1426/82709271.jpg
      By elcorto at 2009-04-21
      ancho = 600.mm
      alto = 720.mm
      n = 24
      r = 100.mm
      edges = entities.add_edges([0, 0, 0],[ancho/2,0, 0],[ancho,0,0],[ancho, 0, alto],[0, 0, alto],[0, 0, 0],[ancho/2, 0, 0])
      circle = entities.add_circle([0,ancho/2,0], X_AXIS, r, n)
      base = entities.add_face(circle)
      base.followme(edges)
      http://img220.imageshack.us/img220/8352/72683910.jpg
      • M
        mattscar
        In the first case, you should should create a curve instead of an array of Edges. Replace
        with
        edges = entities.add_curve([0, 560.mm, 0],[600.mm,560.mm,0],[600.mm,560.mm,720.mm],[0, 560.mm, 720.mm],[0, 560.mm, 0])
        In the second case, it looks like you want the base to be a semi-circle instead of a circle. You should replace
        with
        arc = entities.add_arc([0,ancho/2,0], [0, 0, 1], X_AXIS, r, 0.degrees, 180.degrees, n)
        arc << entities.add_line(arc[arc.length-1].end, arc[0].start)
        base = entities.add_face(arc)
        Hope this at least gets you closer to solving your problems.
        Matt
        • D
          DIEGO-RODRIGUEZ
          muchisimas gracias por tu ayuda.
          • D
            DIEGO-RODRIGUEZ
            How can I put the two codes in a single dialog box?
            And HOW DO PARAMETER?
            choose=[ "Frente 1", "Frente 2" ]
            enums=[choose.join("|")]
            prompts=[ "TIPO", "Ancho", "Alto", "Espesor"]
            values=[@choose, 600.mm, 709.mm, 19.mm]
            results=inputbox prompts, values, enums, "Parametros del frente"
            return if not results
            @choose, $a, $b, $c=results
            ###########Frente 1
            pz=[]
            pz[0]=[0,0,0]
            pz[1]=[100.mm,0,0]
            pz[2]=[100.mm,-c,0]
            pz[3]=[0,-c,0]
            edges = entities.add_curve([0, 560.mm, 0],[a,560.mm,0],[a,560.mm,b],[0, 560.mm, b],[0, 560.mm, 0])
            ###########Frente 2
            ancho = 600.mm
            alto = 709.mm
            n = 24
            r = 19.mm
            Muchas gracias.
            • TIGT
              If you don't use @xxx in front of the variable name it will work - xxx. If you use @xxx the last values you entered are remembered. Don't mix @xxx and $xxx like this - I recommend you stay with @xxx. However, you must assign the @xxx values before the dialog first runs - like this [###=changes]
              @choose="Frente 1" ### set initial [default] @choose
              enums=[choose.join("|")] ### you just could use emuns=["Frente 1|Frente 2"]
              prompts=["TIPO","Ancho","Alto","Espesor"]
              @a=600.mm if not @a ### set defaults for @a - any changes to @a will be remembered for that session of SUp...
              @b=709.mm if not @b ###
              @c=19.mm if not @c  ###
              values=[@choose, @a, @b, @c]###
              results=inputbox(prompts,values,enums,"Parametros del frente")
              return nil if not results ### 'nil'
              @choose,@a,@b,@c=results ### $a >>> @a etc
              ########### Frente 1
              pz=[]
              pz[0]=[0,0,0]
              pz[1]=[100.mm,0,0]
              pz[2]=[100.mm,-@c,0]###
              pz[3]=[0,-@c,0]###
              edges=entities.add_curve([0,560.mm,0],[@a,560.mm,0],[@a,560.mm,@b],[0,560.mm,@b],[0,560.mm,0])### a >>> @a etc
              facez=entities.add_face(pz)
              ### etc etc
