    Strangely cut scene, why??
    3 Posts 3 Posters 341 Views 3 Watching
      mameluk
      Hi, I am totally new here:-)
      Although, I have got a serious trouble with sketchup 6.
      I modelled a scene in sketch up 7 in the school, i saved it as sketchup 6 file. But in bith versions 6 and 7, it cuts the scene somehow.
      If i am using the perspective view, 35 deg, i am not able to come closer, unless it cuts the scene. I have to use 1deg field of view to come closer, but it distort the perspective!
      Do you know, why is this happening?
      somehow cut
      the same scene from distance
        Hi Mameluk,
        Yes, you are close - some of the issues like this (called "clipping") can be fixed with changing the FOV. See the suggestions here to read more about this:
        http://sketchup.google.com/support/bin/answer.py?hl=en&answer=36261
        (I cannot see your axes for instance; are you by any chance not too far from the Origin?)
        • K Offline
          Kus
          I am a beginner, but I can't help my self... It looks like a miss-placed section plane.. try to set section planes on in the view toolbar...
          Hope that I am right 😳
