Rendering SketchyP. animations with Kerkythea
Hello all,
I am wondering if it is possible to render animations made with Sketchy Physics.
When i export an animation i get of every frame one .skp file.
Now i can export every model to a Kerkythea known file type and render every model but that is gonna take a very long time.
For example a movie of 5 seconds, 25 frames in every second means i have to render 125 images with the hand.
Isn't it possible that kerkythea converts every skp file and also makes a render of every file? I don't think that is to hard.
Greets,
Jurriën -
@jppilot said:
Hello all,
Greets,
Jurriënpossibly. i don't use any renderers so i don't know for sure. But you will still have to edit the renders together to make your animation again. if you want an animation of your model i would download something like hypercam from the web and use that.
Ty for your reaction
I already know how to make the images together to a movie.
I do this with VirtualDub (freeware).
Recording with fraps is no option for me. Most models are to complicated to work smoothly.
like this one:
like this one:
hyper cam allows you to set the record rate in frmaes per second and playback rate in frames per second. laggy models can be recorded at 10fps and played back at lets say 40 fps
Yeah oke you are right.
But i'am afraid that is not the same quality as the renders.
(i'am making a movie of my fairground models with camera movement.) -
I wrote an API to allow SkIndigo and Kerky to write out animations. But I don't think anyone has implemented it yet. Since the render plugins are similar I expect once one is done they all will be.
as far as i know there is no object animation render plugin available at this point.
it looks like a new version of skindigo (su - indigo)is not that far away that will handle this
you find more info and a video here: http://whaats-up.blogspot.com/
Register LoginAdvertisement
