Ruby - WebDialog.set_html() and string with null character
When the string containing null character is passed to WebDialog.set_html() the page is loaded up to this characted.
Here is the test case:
NASTY_STRING = "asd\000dsa" UI.menu("Plugins").add_item("test set_html") do dlg = UI;;WebDialog.new("test set_html", true); dlg.set_html(NASTY_STRING) dlg.show() # only "asd" is displayed end UI.menu("Plugins").add_item("test set_file") do dlg = UI;;WebDialog.new("test set_file", true); temp_file = ENV['TEMP'] + "\\test_set_file.html" File.open(temp_file, "wb") do |file| file.write(NASTY_STRING) end dlg.set_file(temp_file) # only "asddsa" is displayed dlg.show() endI understand this is pretty nasty edge case, but still can produce mind boggling results/surprises.
NULL characters aren't allowed in HTML. And NULL characters are in C (I think) used to terminate a string.
Register LoginAdvertisement
