    Ruby - WebDialog.set_html() and string with null character
    2 Posts 2 Posters 420 Views 2 Watching
      dolzenko
      When the string containing null character is passed to WebDialog.set_html() the page is loaded up to this characted.
      Here is the test case:
      NASTY_STRING = "asd\000dsa"
      UI.menu("Plugins").add_item("test set_html") do
      	dlg = UI;;WebDialog.new("test set_html", true);
      	dlg.set_html(NASTY_STRING)
      	dlg.show() # only "asd" is displayed
      UI.menu("Plugins").add_item("test set_file") do
      	dlg = UI;;WebDialog.new("test set_file", true);
      	temp_file = ENV['TEMP'] + "\\test_set_file.html"
      	File.open(temp_file, "wb") do |file|
      		file.write(NASTY_STRING)
      	dlg.set_file(temp_file) # only "asddsa" is displayed
      	dlg.show()
      I understand this is pretty nasty edge case, but still can produce mind boggling results/surprises.
        NULL characters aren't allowed in HTML. And NULL characters are in C (I think) used to terminate a string.
