    Search & Replace Name
    6 Posts 4 Posters 517 Views 4 Watching
      alz
      Has anyone come across a Search & Replace plugin for component/group names?
      I've got a scene with dozens of objects that need to shift from one # to another # -- it's a real bear going in and doing it manually for all the objects.
        remus
        Im not sure if it's what your looking for, but if you go to the components window and right click a component there is a 'select instances' (find) option and a 'replace selected' (replace) option.
          alz
          Yeah, I knew about how to replace physical components -- I was looking for a way to rename components. So if I have MyComponent_AB YourComponent_AB in the Outliner, I could rename the _AB to _YZ. Now they'd be called MyComponent_YZ and YourComponent_YZ.
            remus
            So you did 👊
              azuby
              Are you familiar with regular expressions?
              azuby
                Open the Outliner and Entity-Info windows and dock them together.
                Select the Component Instance in question in the Outliner and its Definition-Name AND Instance-Name appear in the Entity-Info window.
                Edit these as desired.
                Changing the Definition-Name will globally rename the Definition. Each Instance can have its own name too...
                However, if you want to replace parts of names within a set of several definitions' names [like "AB" with "XY"], then to do this globally you need something this:
                ### this does all definitions' AND instances' names; edit 'text_go=/text_in=' to suit...
                text_go="AB";text_in="XY";Sketchup.active_model.definitions.each{|defn|defn.name=defn.name.gsub(text_go,text_in);defn.instances.each{|inst|inst.name=inst.name.gsub(text_go,text_in)}}
                ### remove the defn.name... part to leave them alone OR remove the defn.instances... part to leave them alone...
                I'll leave you to make the app/menu etc...
