    OGL Blackout
    1 Posts 1 Posters 665 Views 1 Watching
    • genma saotomeG Offline
      genma saotome
      I'm using SU 6.4.112 and on occasion it has a video problem w/ my nVidia drivers (178.24) as follows: Cursor can move but whatever function it is suppose to perform fails. When I click the MS Windows frame for SU, the contents within the window turn completely black. The window will clear on it's own after a bit but sometimes I have to click twice. When the window returns and I try and perform a SU function again the behavior re-appears. This visual loss may continue for a few more function attempts and then everything is fine again for a while, until it all happens again. I have not observed any pattern of use that triggers this behavior.
      Being curious, I fired up PROCMON.EXE and captured a series of calls when this event occurs. The screenshot from the relevant area is attached (I edited away the REGQUERYOPEN and CLOSE lines so it would fit on one page). The one line I seemed to have cut away that I should have kept was at the very end, a call to a nVidia debug entry in the registry.
      I assume this is a problem I have, not Google, but that said it has occurred w/ multiple versions of the video drivers AND, most interesting, it does notalways occur when I use SU... it fact, in the vast majority of times using SU everything is fine. So I would appreciate some feedback on how to fix this.
      Oh, I do use nHancer so if necessary I can create a custom profile for SU.
      Procmon.exe screenshot.
