    Script for Report on Name and Amount of Components
    6 Posts 2 Posters 542 Views 2 Watching
      artofseeing
      ...i just can't seem to get it right.
      it tried several scripts so far, but none have given me the desired output.
      i even used the generate report function withing SU7PRO.
      what i want is this:
      i would liket to select a group or component or several things within a SU model,
      then run a script within SU that asks me where to put the file and how to name it.
      it should give me one of the following:
      .CSV with attributes NAME and AMOUNT
      or
      .TXT same as above
      or
      .PDF (would be nicest)
      i need no other attributes.
      the thing is i could us componentreport.rb, but it creates a default within a fixed folder.
      i could use componentreporter+, but it wont list me the amounts.
      i could use the generate report from SU7, but it wont list me the amounts.
      and i have to vreate a lot counts from different parts of my models..
      what should i do?
      thx 4 any kind of advice...
      as long as there is a voyage away, there's always a journey back...
      http://artofseeing.carbonmade.com
        artofseeing
        what i do with the reports:
        i need to make lists of parts within my models to give them to someone else
        to be able to order the right amounts...of whatever i select within SU
          artofseeing
          i already had v1.6.
          works prety good thanks πŸ˜„
          maybe i could also use the additional listing of LAYER attributes.
          it creats a component report, which tells me names and amounts.
          it creates an instance report, which tells me which layer its on.
          could i maybe create a combination?
          =.csv telling me NAME; NUMBER; LAYER ?
          thx alot...
            artofseeing
            while we're at it.
            how can i make it ask me where to put the file?
              artofseeing
              okay thanks very much πŸ˜„
              i'll give the modification a try ....
                already had v1.6.
                That v1.6 was ComponentReporter+ this is ComponentReporter++ (v1.1) that does slightly different things...
                It puts the reports in the same folder as the model...
                You could hack a UI.openpanel() to get the folder from a picked file in it ?
                I've tried to write it so it's reasonably self-evident - try small tweaks to see if you can do what you want...
