    Call to Mac users for script portability
    101 Posts 10 Posters 10.0k Views 10 Watching
    • jeff hammondJ Offline
      jeff hammond
      looking good..
      no little square and the rows are smaller
      dotdotdot
      • fredo6F Offline
        fredo6
        Jeff,
        Thanks. That was the reason for the small square. You're the first one to notice.
        For row heights, it seems I have also found the subtilities for Safari (which behaves very differently from IE).
        Could you make a try with the 2 attached files on:
        • the Default Parameter dialog boxes
        • The translation boxes
        • the language definition dialog box (within the translation dialog box, select 'New language' in the combo box at the top left).
        Fredo
        to drop into LIBFREDO6_Dir_31 folder
          jeff hammond
          these ones make the row spacing big again in the default parameters.
          i haven't opened the language boxes lately but they're looking like the original parameters windows.
          this is how they look with the new and old files..
          dotdotdot
          • fredo6F Offline
            fredo6
            Well, this means that Safari definitely takes some freedom with the W3C specifications.
            Can you try this one then?
            Fredo
              driven
              Hi Fredo and Jeff,
              it's working for me now (cheers for the heads up Mac info Jeff) , including arrow keys and shft lock
              and thanks for a nice program Fredo
              I just finished a length of c1962 Moulton bicycle frame tube (tappered and formed thin wall)
              I'm very happy... I've attached pics of both yesterdays and todays LibWeb Parameters
              cheers
              john
              I emailed you some screen shots, won't upload.
              • fredo6F Offline
                fredo6
                John,
                From the screenshots, I see that the top and bottom margins are still a little bit large.
                Can you try with the attached file and tell me if the margins get smaller.
                Fredo
                  jeff hammond
                  yep, the margins are now smaller and almost everything is visible without stretching the window..
                  the only problem i see now is that i have to stretch the window in order to see the 'save' and 'close' buttons for language translations.. also, when i select 'new language' from the 'translate into' dialog, there's no way to stretch the window so i'm not sure if there are supposed to be save/cancel buttons at the bottom.
                  the default parameter dialogue is still ok ( with both libfredo6 and freescale)
                  [btw, i'm moving the windows into these positions for ease of making the screenshot.. normally, these exact two windows wouldn't be opened together.. this is how it looks if i don't change anything and only go Language Translation-> Translate Into -> new language.. ]
                  it's the same with libfredo6 and freescale
                  dotdotdot
                  • fredo6F Offline
                    fredo6
                    Jeff,
                    I am a little bit lost. Are you sure you ever saw the push buttons of the Translation (and Language List) dialog boxes ? It seems you have the same old bug about windows half displayed which I fixed for the Default Parameter box.
                    Just to be sure, I reattach the 2 files that correspond to my current version.
                    Again, many, many thanks for your help to all, I know this is a lengthy process, but actually it did not worked that bad!
                    Fredo
                      jeff hammond
                      Jeff,
                      no, i can't remember ever seeing the buttons for the translation box (though i haven't been checking it with all of the updates.. i've just been looking at default parameters).
                      the translation boxes look like the the default parameter boxes did when this thread started so i guess whatever you did to fix the default params would be the same thing you could do to the translations?
                      oh, no problem.. it's good timing for this because i haven't had any onsite work lately.. just at home with the kids πŸ˜„
                      dotdotdot
                      • fredo6F Offline
                        fredo6
                        Jeff,
                        Do you mean that the Translation box is still 'half-shown' with the latest rb files?
                          jeff hammond
                          yes, it is still half shown using the latest attached files
                          dotdotdot
                          • fredo6F Offline
                            fredo6
                            It means that I did not yet how I fixed it for the Default Parameters box!
                            Could you try this one
                              jeff hammond
                              ok, that fixed it.. the language maintenance box is the only weird one now.. (and i noticed i can stretch it to get to the save/cancel buttons.. there's just no stretch graphic showing at the bottom right)
                              here's where it's at right now:
                              language maintenance:
                              freescale default parameters:
                              libfredo6 default parameters:
                              dotdotdot
                              • fredo6F Offline
                                fredo6
                                If the attached one works on the Language dialog box, then it means I have understood the weird things with the SU web dialog boxes (i.e. the order of set position and set size).
                                Thanks to advise
                                  driven
                                  Hu Fredo,
                                  seems ok to me, try to attach new snap, this site doesn't like me or something...
                                  I been having trouble downloading some of your other work and no joy. Bezierspine.rb for example said I don't have permissions, yet this came without a hitch...
                                  so which one don't work on a mac to save me a little grief.
                                  Ive email screenshot as well
                                  john
                                  mon3rd2009
                                    jeff hammond
                                    yes Fred, you now understand the weird things πŸ˜„
                                    dotdotdot
                                    • fredo6F Offline
                                      fredo6
                                      Jeff,
                                      Thanks a lot.
                                      This 'weird' thing is incredible. Just the order of statements!
                                      I'll consolidate and publish as version f.
                                      Fredo
                                      • fredo6F Offline
                                        fredo6
                                        John,
                                        Do you mean it works or it does not work with BezierSpline?
                                        Otherwise, all my scripts are supposed to work on Mac, this is what Mac users say. I try to keep compatibility because I respect the platform and its users (I used to be one long time ago). It's true that this was hard work for the Web dialogs, but because I intend to use them for more 'operational' objectives, I needed to make sure that I understood enough on how it behaves on Mac.
                                        Thanks for your appreciated contribution too.
                                        Fredo
                                          driven
                                          ok,
                                          so the contextual menu doesn't scroll high or low enough to check all the boxes,
                                          • fredo6F Offline
                                            fredo6
                                            Which contextual menu? In which script?
                                            • 6
                                            • 5 / 6
