    Call to Mac users for script portability
    101 Posts 10 Posters 15.8k Views 10 Watching
    • jeff hammondJ
      yep, the margins are now smaller and almost everything is visible without stretching the window..
      the only problem i see now is that i have to stretch the window in order to see the 'save' and 'close' buttons for language translations.. also, when i select 'new language' from the 'translate into' dialog, there's no way to stretch the window so i'm not sure if there are supposed to be save/cancel buttons at the bottom.
      the default parameter dialogue is still ok ( with both libfredo6 and freescale)
      [btw, i'm moving the windows into these positions for ease of making the screenshot.. normally, these exact two windows wouldn't be opened together.. this is how it looks if i don't change anything and only go Language Translation-> Translate Into -> new language.. ]
      it's the same with libfredo6 and freescale
      • fredo6F
        Jeff,
        I am a little bit lost. Are you sure you ever saw the push buttons of the Translation (and Language List) dialog boxes ? It seems you have the same old bug about windows half displayed which I fixed for the Default Parameter box.
        Just to be sure, I reattach the 2 files that correspond to my current version.
        Again, many, many thanks for your help to all, I know this is a lengthy process, but actually it did not worked that bad!
        to drop into LIBFREDO6_Dir_31 folder
        • jeff hammondJ
          Jeff,
          no, i can't remember ever seeing the buttons for the translation box (though i haven't been checking it with all of the updates.. i've just been looking at default parameters).
          the translation boxes look like the the default parameter boxes did when this thread started so i guess whatever you did to fix the default params would be the same thing you could do to the translations?
          oh, no problem.. it's good timing for this because i haven't had any onsite work lately.. just at home with the kids πŸ˜„
          • fredo6F
            Jeff,
            Do you mean that the Translation box is still 'half-shown' with the latest rb files?
            • jeff hammondJ
              yes, it is still half shown using the latest attached files
              • fredo6F
                It means that I did not yet how I fixed it for the Default Parameters box!
                Could you try this one
                • jeff hammondJ
                  ok, that fixed it.. the language maintenance box is the only weird one now.. (and i noticed i can stretch it to get to the save/cancel buttons.. there's just no stretch graphic showing at the bottom right)
                  here's where it's at right now:
                  language maintenance:
                  freescale default parameters:
                  libfredo6 default parameters:
                  • fredo6F
                    If the attached one works on the Language dialog box, then it means I have understood the weird things with the SU web dialog boxes (i.e. the order of set position and set size).
                    Thanks to advise
                      driven
                      Hu Fredo,
                      seems ok to me, try to attach new snap, this site doesn't like me or something...
                      I been having trouble downloading some of your other work and no joy. Bezierspine.rb for example said I don't have permissions, yet this came without a hitch...
                      so which one don't work on a mac to save me a little grief.
                      Ive email screenshot as well
                      mon3rd2009
                      • jeff hammondJ
                        yes Fred, you now understand the weird things πŸ˜„
                        • fredo6F
                          Jeff,
                          Thanks a lot.
                          This 'weird' thing is incredible. Just the order of statements!
                          I'll consolidate and publish as version f.
                          • fredo6F
                            John,
                            Do you mean it works or it does not work with BezierSpline?
                            Otherwise, all my scripts are supposed to work on Mac, this is what Mac users say. I try to keep compatibility because I respect the platform and its users (I used to be one long time ago). It's true that this was hard work for the Web dialogs, but because I intend to use them for more 'operational' objectives, I needed to make sure that I understood enough on how it behaves on Mac.
                            Thanks for your appreciated contribution too.
                              driven
                              ok,
                              so the contextual menu doesn't scroll high or low enough to check all the boxes,
                              • fredo6F
                                Which contextual menu? In which script?
                                  driven
                                  Fredo, did the pic come?? i'll re-attach. freeScale. bottom box after TopMenu
                                  your delightful scripts, when I can download them (a problem with this site), and get them in the right place (my fault) are fantastic to use on the Mac, my comment was more about if any of the earlier ones had been absorbed into FreeScale or Pushpull, or outdated by SU7, etc.. then I will not try to find them now.
                                  cheers john
                                  again maybe
                                  • 5 / 6
