    Window Proportions Question
    18 Posts 9 Posters 2.1k Views 9 Watching
      Is there anyway with Ruby (or some other tool) to set the entire SketchUp window to a specified aspect ratio? I'd like to be able to easily set my sketchUp window to match the proportions of a 640x480 image area for when I make video screen grabs. It might be that I'd want to set it to 16x9 proportions at some point, too. Is there some way to do that? Is this a registry editing thing? If so, is there a practical way to edit the values without going into regedit?
        remus
        I think this should do what you want http://www.brianapps.net/sizer.html
          bubbalove
          Remus, so would it size the workspace to 640x480 or the whole window?
          "Success consists of going from failure to failure without loss of enthusiasm." - Churchill
            remus
            It resizes the whole sketchup window.
              Mange takk Remus. That could work.
                dylan
                Dave let us know if it works please.
                I may be interested in this.
                http://dmdarchitecture.co.uk/
                  I just downloaded and installed it. It works as advertised. I haven't tried capturing video yet but I don't see why there's be a problem at this point. It lets you create your own window size. I ended up setting mine to 1500x1125 which is the same proportions as 640x480 but my toolbars still fit across the top.
                  Thanks Remus. This looks great.
                    remus
                    i think it was coen who found it, so he's the man to thank.
                      mirjman
                      dave - don't forget to take into consideration the width of the 'scene' tabs at the top when you start setting up your animation
                        Thanks for that reminder. When I set up to do a video capture for a tutorial, I include the entire SketchUp window including the toolbars so those scene tabs get included if I use Scenes.
                          film and stage plugin won't affect the entire SketchUp window though. It only masks the drawing space.
                          • JClementsJ Offline
                            JClements
                            Previs Film & Stage plugin will do it ... sort of.
                            You can set your own aspect ratio and name it (you can edit the camera.txt file), then grab the window frame and resize to eliminate the gray bars.
                              JClements
                              By resizing the window to the graybars you'll have image size you want. Just have to be careful in being accurate to get the gray bars to disappear.
                              I am interpretting the "SU window" as the white drawing area.
                                Hi John, my original question was about the entire SketchUp window which includes the toolbars, menu headings and so on. You are correct however. If I wanted to show only the drawing window the Film and Stage plugin would be useful for setting the its size.
                                • Chris FullmerC Offline
                                  You could also make a 640x480 black image and set it as your desktop background, not stretching, no tiling. then size the window to cover it up....... might work?
                                  Chris
                                  All my Plugins I've written
                                    Yes, that could work Chris. That sizer application works perfectly for what I need.
                                    • P Offline
                                      putnik
                                      remus, great little program, thank you.
                                      http://keshas.info
                                        Matt666
                                        +1 for this cool program!
                                        Frenglish at its best !
                                        My scripts
