    [Plugin Library] LibFredo6 - v16.4b - 21 Nov 26
    2.3k Posts 597 Posters 16.1m Views 599 Watching
    • D
      DRydah13
      I'm having problems with the updated version.
      The error says E6B.so didn't meet Windows signing requirements or violated a code integrity policy.
      It was working fine yesterday
      This explains why LibFredo6 16.4a is installed and enabled but cannot load, leaving Curviloft and your other Fredo6 extensions unable to function.
      SketchUp 2026 / Windows 11
      LibFredo6 version 16.4a
      Error: NameError (uninitialized constant E6B)
      Windows Code Integrity Event ID: 3077
      Blocked component: SU26-0/E6B.so
      Windows Smart App Control: ON
      Request: A trusted, properly signed E6B component compatible with Windows Smart App Control.
      • D
        DRydah13
        I have confirmed the cause of my LibFredo6 16.4a failure in SketchUp 2026.
        Windows 11 Smart App Control is blocking the E6B.so component.
        Windows Event Viewer reports Code Integrity Event ID 3077, indicating that E6B.so does not meet the required signing policy.
        The extension worked normally on November 17, 2026, but stopped loading on November 18.
        Can you provide a digitally signed E6B.so component compatible with Windows 11 Smart App Control, or recommend an officially supported solution that does not require disabling Windows security?
        I rely heavily on JointPushPull, Curviloft, and FredoScale for my professional design work.
        • A
          aprogon @fredo6
          This post is deleted!
          • A
            aprogon @fredo6
            Hi @fredo6
            By “none of them work,” I mean that when I click on any of the tool icons, nothing happens. No error message appears. It's as if I hadn't clicked anything at all. The same thing happens when I go to Tools > Fredo Collection. I click on any of the menu options, including the License option, and absolutely nothing happens.
            As I mentioned to Dave yesterday, I uninstalled everything again and reinstalled it through the SketchUcation ExtensionStore. I restarted SketchUp, but nothing changed. I also restarted my PC, with the same result. So I went back to working in SU 2026, where everything works fine.
            The strange thing is that I just opened SU 2027 to copy the information you requested from the Ruby Console, and I tried the tools again. Now they work! I have no idea why, since nothing has changed since yesterday. But anyway, the problem seems to be solved.
            Thank you very much for your help!
            • B
              bjorn_sawilla Newcomers
              More details on the above case
              • fredo6F
                fredo6
                NEW RELEASE: LibFredo6 v16.4b - 21 Nov 26
                LibFredo6 16.4b is a maintenance release. It includes changes related to:
                • Compatibility SU2027
                • Technical adjustments
                • Bug Fixing
                If you use LordOfTheToolbars, please upgrade it to LordOfTheToolbars v4.2a. Otherwise, LOTT will not be activated
                Requirements: SU2017 and above
                See plugin home page of LibFredo6 for Download of LibFredo6.
                Main Post of the LibFredo6 thread
                • 113
                • 114
                • 115
                • 116
                • 117
                • 117 / 117
