    Organize plugins?
    6 Posts 5 Posters 886 Views 5 Watching
      Tekkybot
      hi. is there a way to organize the plugins folder. it seems like such a mess its bothering me. can i rename files and use sub folders? or does that ruin the scripting language?
        Tekkybot
        i have all these weird folders and files that i don't understand, like, libfredo6, jpp dir, lib traductor, rdedir, dir10, z loader, the names are really intimidating 😞
        • mitcorbM Offline
          mitcorb
          This has been discussed before in the forum. Do a search with your subject as the keywords, and see what comes up.
            remus
            You cant rename the files or move them about within the ruby folder, it will break the scripts 😉 I'd suggest just sucking it up and forgetting about it.
              And why do you bother with the folder structure of your Plugins folder? I don't really have a look at the Windows folder structure either. 😒
              • kenK Offline
                ken
                I have and use this plugin http://www.alexschreyer.net/projects/plugin-loader-for-sketchup/.
                I use the following Plugin folder layouts.
                Plugin – This is where I store every plugin that I want to run automatically.
                Also I have plugin in this directory that I wish for the Plugin-loader to install and not be loaded automatically. These plugins, I remove the file type .rb, just leaving the file name as “GetLines” not “Getlines.rb.” This way, the plugin remains in the plugin folder, but will not be loaded autmatically. But will load with the plugin-loader, because "plugin-loader" adds the file extension, “.rb”.
                And the plugins that I wish to be loaded by the “plugin-loader” that I have chosen to remain in the plugin folder, I will remane by adding a number the front to the name, such as “1 – Getline.rb”. This will put the plugin at the top of the plugin in folder so I don’t have to hunt for it down in the directory.
                Other plugins I move to one of the following directories below, selecting it from the “plugin-loader“ when I wish to run the plugin. Works like a charm.
                Another thing I do, is I rename the plugin, i.e. Getline.rb may be renamed “To Get All Loose Lines– Getline.rb”. Note, I usually have the original name after the “-“ so I always know what the original plugin name was for future reference.
                I do this reference annotation renaming so I have some hint of exactly what the plugin does. I have not found a plugin that would not run from plugin-loader that I have rename by this method.
                My directory loayout, and I am thanking Didier Bur for the layout from his web page.
                000 Steel Beams Angle
                001 Animation – Scenes – Camera
                002 Architecuture
                003 Geometry – Drawing
                004 Editing
                005 Material – Colors – Rendering
                006 Selection – Layers
                007 Survey - Terrain Contour
                008 Text
                009 Files – Import – Export
                010 Google Earth
                011 Misc
                012 Zip – Zar – Scripts
                013 Script TXT Files
                014 Data Files for Script Testing
                015 Plugin exe Install files
                016 Script Tutorials
                Hopes this helps. I know it cleaned up my drop drown plugins list.
                Ken
